The below rule has been running with the mode in "normal" for some weeks. Tonight I tried the "PartyMode" and it did not run as expected:
The "PartyMode" is simply a mode to delay turning lights off until 1:00AM
This afternoon I set the Mode to PartyMode and verified it in from the settings menu.
What happened:
Rule: 1st ELSE-IF will turn the listed lights off at 11:16PM if the Mode is NOT "PartyMode"
--> Tonight it turned off the lights at 11:16PM even though the Mode was PartyMode"
--> Via Alexa turned lights on again at 11:18 PM
Rule: 2nd ELSE-IF will turn off the lights listed at 1:00AM and reset the mode to Normal.
--> Did not turn the lights off but did set the mode back to Normal.
I've read the rule many times tonight and can't see the issue, I'm hoping a 2nd set of eyes can help.
John
