Restart effects included a ST arrival sensor and a basement 3R temp/hum sensor dropping off the zigbee mesh, as well as the Envisalink integration not disarming this morning as usual.
The hub is powered directly off a battery, so I don't think a momentary did it.
Interestingly, when I brought the 3R temp/hum sensor upstairs to re-pair, I noticed that the display would not change, even when I breathed on it, etc.
It only changed, and started working again, after re-pairing.
I hadn't thought the digital display on the sensor would've been affected by dropping off the mesh.
