Today instead of Hubitat announcing the date as the 1st of June, it is announcing it as the 6th of January I'm using the textToSpeech(string) function within VLCThing passing in the %date% as part of the string from a Rule Machine App.
textToSpeech("Door has been closed at 07:00 AM on 06/01/2019")
Thank you Rob, you helped me figure it out. If you use Emma, or presumably any of the other British English speakers, they will assume that %date% is formatted by UK standard. Kendra and the other US English speakers assume that %date% is formatted by US standard.
As for the other parts of the system, From what I can tell, VLC just plays whatever mp3 file is sent to it. It does not do the TTS. VLCThing calls the textToSpeech() function provided by Hubitat. Hubitat seems to use Amazon to create the audio file from the text.
So the question is, can users change the date format for %date% ?
