I'm developing a driver for JRiver Media Center. When I put my device on on a dashboard, I get the previous and next buttons, mute/unmute, volume slider, and track information. What I don't get is a play/pause button. How do I get that to show up?
I think in most cases what you see is what you get on the dashboard templates. When I use the Music Player template for my Sonos speaker I see the play / pause icon alternate depending on what I am doing, showing a pause icon when I am playing a track and a play button when nothing is playing. Do you not see this with your device / tile?
EDIT: Actually, you quite clearly answered that in your question.... There must be a capability your are missing.... Apart from the MusicPlayer capability, the only other one that seems likely is MediaTransport.
Are you issuing a sendEvent for the status attribute of MusicPlayer? Here's a snippet of my code that handles that (to illustrate statuses that seemed important):
def tempStatus = ""
switch(resp_json.status.toString())
case "stop":
tempStatus = "stopped"
break
case "play":
tempStatus = "playing"
break
case "load":
tempStatus = "loading"
break
case "pause":
tempStatus = "paused"
break
sendEvent(name: "status", value: tempStatus)
