Somehow I ended up with two versions of the same app code on my hub. When I try to delete one, I get a notice that it's in use by certain apps. Is there a way to change which version of app code is used by an app, so that I can delete one of the versions of code?
How many apps itself are installed? Do both versions of the code give the same issue on removal? If so you need to delete the code/app and re establish the devices under the single code/app
Yes, both versions give the same issue on removal, but with respect to different apps. I don't understand how my Withings apps are using versions of QuickChart code.....
Have you got HPM installed?
If so, you might try a match up. It can happen that if you install an app or driver manually and later on via HPM or another package manager that the existing implementation remains while a new one form the package manager is installed alongside
Yup, that did it. Thanks!
