I would like to create a rule to open my garage door between 7:40 am through 8:05 am Monday through Friday when I open my back door contact sensor. I need al of these conditions to be met in order to open the garage door. Is this possible?
i was too fast missing end-if at end.. but you get the idea
you should change the title also, there is only one trigger not multiple.. the others are conditions..
What took you so long?!
Yup. One suggestion (also made earlier by @kahn-hubitat), end your Actions with a "END-IF". It doesn't matter so much for this rule, but may in the future if you make rules with nested IF blocks.
I canāt find where to add END-IF. Maybe Iāve gone stupid. Smart homes apparently are not for stupid people.
It should be added as the last statement of the actions portion of your rule.
Hereās the relevant part of the rule 4.0 documentation:
https://docs.hubitat.com/index.php?title=Rule-4.0#IF-THEN-ELSE
Thanks for the help. I've fixed that rule. Also, is there a way to close the garage door when my phone disconnects from my Wi-Fi connection since it is listed as a device. I would like to use that instead of gps geofencing.
