I've been experiencing the "multiple events for single action" bug which has been mentioned numerous times in these pages.
I think I found a possible clue for you guys to check into.
Using MakerAPI, I did a "Get All Devices with Full Details" report on a couple of lights and outlets. I've pasted the resulting JSON below. Notice that if you look in the "command" section, you see the "on" and the "off" commands each repeated twice for these devices. This seems to be happening in the "Generic Z-Wave Outlet", Zooz Zen25 Double Plug, and a few Zigbee lights. I also have problems of multiple events for Z-Wave dimmer devices, but I haven't seen this repeated command problem for those devices.
I"m currently running firmware 2.2.2.129 (I had to downgrade from 2.2.3.148 as I had too many problems with that one), but given the problems I was having with 2.2.3.148, maybe this problem exists there too.
"name":"Generic Z-Wave Outlet",
"label":"Backyard Landscape",
"type":"Generic Z-Wave Outlet",
"id":"35",
"date":"2020-10-03T00:25:36+0000",
"model":null,
"manufacturer":null,
"capabilities":[
"Switch",
"Configuration",
"Refresh",
"Actuator",
"Outlet"
"attributes":{
"switch":"off",
"dataType":"ENUM",
"values":[
"on",
"off"
"commands":[
"command":"configure"
"command":"off"
"command":"off"
"command":"on"
"command":"on"
"command":"refresh"
"name":"Generic Component Dimmer",
"label":"Bonus Room LZW36 Light",
"type":"Generic Component Dimmer",
"id":"218",
"date":"2020-09-11T23:11:50+0000",
"model":null,
"capabilities":[
"Switch",
"SwitchLevel",
"Refresh",
"Actuator",
"Light",
"ChangeLevel"
"attributes":{
"level":"100",
"dataType":"ENUM",
"values":[
"on",
"off"
"switch":"off"
"commands":[
"command":"off"
"command":"off"
"command":"on"
"command":"on"
"command":"refresh"
"command":"setLevel"
"command":"startLevelChange"
"command":"stopLevelChange"
"name":"Zooz Double Plug",
"label":"Kitchen Cabinet Parent - Lights Over Desk",
"type":"Zooz Double Plug",
"id":"270",
"date":"2020-10-03T00:10:47+0000",
"model":null,
"capabilities":[
"Switch",
"Configuration",
"Refresh",
"EnergyMeter",
"PowerMeter",
"Sensor",
"Actuator",
"VoltageMeasurement",
"Outlet"
"attributes":{
"current":"0.14",
"dataType":"NUMBER",
"values":null,
"currentHigh":"0.14",
"currentLow":"0",
"energy":"3.41",
"energyDuration":"21 Days",
"power":"10.3",
"powerHigh":"10.6",
"powerLow":"0",
"switch":"on",
"voltage":"124.9",
"voltageHigh":"125.8",
"voltageLow":"0"
"commands":[
"command":"off"
"command":"off"
"command":"on"
"command":"on"
"command":"refresh"
"command":"reset"
"name":"Generic ZigBee RGBW Light",
"label":"Color Bulb Left",
"type":"Generic ZigBee RGBW Light",
"id":"462",
"date":"2020-10-02T23:52:26+0000",
"model":null,
"capabilities":[
"Switch",
"Configuration",
"SwitchLevel",
"Refresh",
"ColorControl",
"Actuator",
"ColorTemperature",
"Light",
"ChangeLevel",
"ColorMode"
"attributes":{
"RGB":null,
"dataType":"ENUM",
"values":[
"on",
"off"
"color":null,
"colorMode":"RGB",
"colorName":"Green",
"colorTemperature":"2702",
"hue":"33",
"level":"71",
"saturation":"100",
"switch":"on"
"commands":[
"command":"off"
"command":"off"
"command":"on"
"command":"on"
"command":"refresh"
"command":"setColor"
"command":"setColorTemperature"
"command":"setHue"
"command":"setSaturation"
