Multiple Dashboards
I have created a dashboard for each room (bedroom, living room, etc.), with its respective devices. I have also created a master dashboard but I only want it to display all the individual room dashboards. How do I do that?
I want to be able to use a wall-mounted tablet to show the master dashboard which will show all the other dashboards , weather, time, etc.. When you select say the bedroom, it will then show the bedroom dashboard or be able to go back and choose living room dashboard.
there is a special tile to create dashboard links. I've done exactly what your are.
Yes, I just found it, how do I edit the name of the tile? Say to bedroom?
I also have navigation tiles "behind" others.. in other words, picking "Downstairs" would take me to the downstairs dashboard and on THAT I have nothing in the downstairs "slot" - it's blank. I do however "zoom in" via a tile. For example, Motion Sensors has a Lux tile "behind it to select the same set of devices, same placement, just displaying their Lux values, instead of Motion/battery.
the tile will use the name of the dashboard it is linking to. within the tile you can turn off the dashboard type from being displayed on the tile also.
Cool, I found the little drop down. Since I have your attention, where do I change the size and colors of the tiles, like csteele has done above, all I can get is the yellow-green
in the gear top left then templates. you can also tweak the css if you so choose.
Thanks much, I have looked for that forever!!!
One more thing...what are the Day mode tiles used for??
The mode tile will show what mode your are in. Depends on how you define modes. Day/night/away. And what those modes do.. best thing to do is play with everything.
Like this ?
@gdkramer: Yes, I got the tile colors & sizes. Sokra said you can tweek css, so I might look into that when I get more time as well.
Thanks everyone who has replied and helped me. I hope to soon return the favor
Your welcome.
I asked many questions and still do. The community here is great. Need help just ask.
