I added a second hub to a second home ID, all seemed fine on my phone app. App shows two Hubs ID and AZ. My web browser also showed two Hubs, although only connected to the ID Hub, I have to remote into the AZ Hub, all is fine there. However with adding the first device to the ID home, I was unaware it was adding it to the Hub in AZ not in ID, so I have three dashboards within the AZ Hub that are labeled ID, which I need to delete. Any help
So you just want to remove the dashboards? That can be done from the Apps page on the hub web UI.
