Multiple bulbs, outlets and switches not responding
C-7 hub
Person - 2.4.1.155
Strange occurrence, no changes to my setup but have multiple switches, outlets and bulbs not responding.
I have others that are working however.
I have zigbee bulbs. Some are working and others are not
Snzeo outlet not working (coolcam power plug)
Zwave switches not working (jasco) (works manually at the switch)
Zooz Zen Dimmer switch not working (works manually at the switch)
Cannot control via Alexa, HU app or Home app on iPhone.
I assume that those devices were all working before - if I had this issue, I would first power off the hub, unplug it for 1 minute, then plug it back in.
If the issue continued after another hour or so, I would then do a reboot with the « advance » setup checked and the « rebuild database » checked.
In parallel with this, I would start looking at the logs to see if any errors are thrown for the problematic devices.
If you see errors and don’t know if they might be related, post a screenshot. Others may have an idea of what they mean.
You may also want to post a screenshot of the full Z-Wave Details screen.
Powering off and waiting a bit and then powering back on seemed to fix it.
I had tried to restart via the app several times and that did not seem to work. This however did.
Thanks!
