Please add the support for multi line messages. Right now all messages are just one continues line. I have tried many things to get multi lines, but I believe the way it is currently setup it cant handle multi lines as all return line codes I try come out as text.
I would like it if the Message area was a box instead of a line so we can use the return to create a new line. Same for variables that are strings.
My goal is to be able to have a header (The type of alert) and then the next line starts with the message. and be able to start a new line with each device the might be referenced.
Second request (Or i am unsure how)
I still have not found a way to do the following. If system is armed, then send me a message with all devices that are open. (Doors) and then (Windows)
So it would trigger when the system is armed. and then look at all the contacts I select (AKA Doors) and then look at all the contacts i select (Windows) and it they are open I get a notification they are open.:
Result would look something like this:
--System Armed--
Contacts Open(Doors)
Back Door(Windows)
Front Room Window
Master Bedroom Window
