I have Lightify A19 Tunable White Bulbs (two).
- endpointId: 03
- application: 92
- model: LIGHTIFY A19 Tunable White
- manufacturer: OSRAM****strong text
However when I use the Color bulb setting in the dashboard if the bulb is one I cannot close out of the panel.
Only when I turn the light back off I can close the panel. Has anyone seen this? I don't know when this started happening.
Thanks,
I do not have that type of bulb, but I check my Sengled bulbs and they are working OK here.
Does this happen on all browsers, and via the app? Is that the only bulb type you have/does it do it for all?
Thank you for your response. Both Browsers and Application this happens in. I have Chrome and the New Edge for browser this happens in. Moreover, the Hubitat application too this happens in. I have the OSRAM Lightify A19 Tunable White. They aren't RGB only Temp for the type of light.
Let me know if that makes sense.
Thanks!
I was hoping that the new platform update would resolve the issue. However, it has not resolved the issue. It's the strangest thing I've seen. Let me know if anyone has seen this before.
I run into this bug all the time..toggle the bulb in some way. turn in down a little or change the temp and then it will close. This bug happens in the app and through a browser.
Thanks! Dashboard bug I assume? Thanks I will give that a try.
tagging @bobbyD are you aware of this 'bug'?
Thank you TechMedX. Yes moving something allowed to to work temporarily,
@TechMedX @bobbyD Have either of you seen this?
Thank you again.
I have not, I do not have those devices. @bcopeland might be able to help as well.
I don't have those devices either. its happened to me using ikea 4700k e12 bulbs and sengled 5k e26 bulbs. so it isn't just the devices he is having problems with. also I did own 1 cree bulb for about a week and it did the same with that.
Agreed. I don't think it a device issue. It is a Hubitat dashboard issue. I had older bulbs zigbee. I bought new/different model same manufacture with a hub. So Hubitat talks to Hub/gateway. Still see the same issue.
I just had this problem using the color bulb tile as well. Using ChromeOS 84.0.4147.127.
