My electrician just installed my first of 16 Zigbee Switch MS-104z into wall switch units.
The prove the system we tested that two way switching still works in each room; the unit beeped and was paired with HE without issue and now appears in the dashboard but is unresponsive. I did post this into our FB group as I was unable to include any images in here.
Is it possible that I could be using the incorrect driver ? I set this up as a "Switch" was this correct ?
This device should work with the generic zigbee switch driver.
After changing to this driver, be sure to hit configure.
Please report if that driver works with this device.
Can you look at event history for the driver named Device in the logs?, I'm looking for a log line starting with fingerprint, then I can update the driver for this device.
Hi Guys, Now that I have received my C7 I need to get these back into pairing mode, does anyone know how to achieve this without rewiring them ? Wouldn't it be great to be able to backup and restore from C5 to C7
Many thanks
Paul
Sorry can't help here.
Last time I re-paired one, it was wired up on a bench.
Only thing I could think of, is unpair from c5, turn switch on/off 3x during discovery mode on c7
Hi Paul
Can I ask if you used the phone app for pairing the 104, or did you just use the reset button / beep procedure ?
I just received one of these switches but cannot pair it to my hub.
Would appreciate your insight.
Hardy
ok. Thanks. Sorry for my ignorance but this is my first device and I've never played with zigbee before.
Is there a specific order to start pairing ? Trigger the hub first or the device ? Does it matter ?
I get the beeps going on the switch but the pairing screen stays empty.
Does the hub need to be connected to the internet ? I thought these run standalone.
ok. Seems that the reset procedure for this switch is not documented. But I got it now and it is detected by the Hubitat.
Next question - I dont seem to be able to do anything with it. I tried some rules to use switch states set the modes, tried the buttons on the web page showing the device, also tried enabling debug and watching for events.
I dont have the exact device available in the list, and there is one Tuya device that I've used to try and make something work. (Tuya Zigbee Scene Switch)
I can see that the device states, number of buttons is reported as 2, which is correct.
Actually, it's 2 switches and 2 relays.
I saw some custom code but no idea how to set it up. Dont know if it helps. ( zigbee2mqtt dot io slash devices slash MS-104Z.html )
You're a legend. Thank you.
The generic worked but could not see the 2 endpoints (switches) in this device.
NUE switch does and seems right.
Thanks again
