I have been experimenting with the MQTT Exporter app. I had it working with Influxdb3 to export all device data. I found that there was a issue with one of the devices and went in to remove it. The page froze in the UI and i ended up having to reboot the hub. After doing it appears that MQTT isn't working at all. I am using the built in MQTT Service option
The error messages from logs are
app:24162026-03-30 07:47:30.025 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:47:15.012 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:47:07.492 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method main within 120 seconds (main)
app:24162026-03-30 07:47:00.216 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:46:45.013 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:46:30.029 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:46:15.046 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:46:00.363 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:45:45.011 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:45:37.856 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method main within 120 seconds (main)
app:24162026-03-30 07:45:30.030 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:45:15.082 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:45:00.190 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:44:45.012 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:44:30.080 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:44:15.014 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:44:00.119 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:43:45.012 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:43:30.040 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:43:15.049 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:43:00.116 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:42:45.012 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:42:39.062 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method main within 120 seconds (main)
app:24162026-03-30 07:42:30.062 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:42:15.028 PMerrorjava.lang.RuntimeException: Failed to acquire semaphore for method checkMQTTConnection within 120 seconds (checkMQTTConnection)
app:24162026-03-30 07:39:15.010 PMwarnMQTT export integration disconnected from broker.
I have tried making addtional changes and saving it. I have disabled and then re-enabled the integration. I have removed the app and then reinstalled it. I have rebooted the hub with the option to rebuild the DB. I have confirmed the user id and password
As a test i attempted a telnet from the Influxdb3 host making the MQTT call. I was able to connect to my dev hub which is still working on port 1883, but the hub i am having issues with that has the significant number of devices is just refusing the connection. It just seems like it is completely Borked non functional. Intereseting the integation is reported as running on the hub from the Integration UI.
Anyone else seen this or have any suggestions. @gopher.ny or @bobbyD do you have any ideas?
