MQTT controller switch
I would like to us a multi-button wall switch (flashed with Tasmota) that has one button on a relay that controls load as conventional one-pole switch, and 7 buttons that each output two MQTT signals (either single or double press). If i set up a rpi as a MQTT broker, how do I actually use the MQTT outputs as triggers to initiate Hubitat rules? Getting the one-pole to work is easy, just not sure how to get the MQTT part of this working with Hubitat. Would like to use the MQTT output as a trigger in Rule Machine if possible. TIA for any help.
