Moving Konnected to different subnet
I am moving all my WiFi devices to a different subnet and need to leave my Hubitat and all the other hardwired devices on the old subnet. New subnet is 192.168.86.x and old is 10.10.50.x
Konnected devices are still able to see the Hubitat (since it hasn't changed its IP) but the Hubitat is unable to see the Konnected devices because they are at a different IP and I don't see where I can tell the Konnected App to change the address Hubitat believes they are at and discovery on a different subnet doesn't work either. Any suggestions (other than don't have them on different subnets)?
How are you routing between the nets?
Tagging @nate from Konnected...
Yeah, that would be a problem since I have two Konnected devices so port forwarding back through the WiFi router wouldn't work. Konnected to Hubitat is fine, the WiFi router manages that and everything is still working except I can't talk to the Konnected from the Hubitat so my beeps when doors are opened doesn't work.
I was running the WiFi router in bridged mode but that is looking like it won't work.
But let me change the direction of the question, let's say I wanted too move everything to a different subnet but everything is on the same subnet. Do I have to throw away a ton of work or can I change IP addresses for the Konnected devices?
You can change the IP
In konnected app click the device name then this device status
Then at the bottom click reconfigure wifi
I'm sorry this is old, but I'm having the exact same issue and the answer is not quite right.
The reconfigure wifi will adjust the konnected device.
I still don't see where to tell hubitat what the new IP address of the device is though.
