Why would you need both of these? I'm not understanding.
How many motion sensors are we talking about? Just the one for the bathroom?
For this, because you also want to cancel your delays if motion goes active again, your trigger will have to be motion changing. and that's also a hint about how you would set this up.
Thanks. I'll give another go writing in the morning.
Justification being basically that there's probably some very small chance of a false positive motion wise, so while I'd generally want those things off in half an hour, a 35 minute shower isn't out of the question probably. An hour however seems way more likely to be some kind of flood inducing error and should go off regardless of what the motion sensors are getting. Worst case someone turns it back on if it actually was intentional.
Is there any issue in having a command to turn something off if the object already is off? I know at least occasionally in smart things that exact issue resulted in the off acting like a toggle.
