I'd also mention that you should try to craft your rules the way your family and guest use your house. With a little effort the dashboard could become unnecessary. I haven't touched a dashboard in 6 months and my family don't even know about them. Just be sure to get their feedback if you take this approach. We don't even use voice control other than turning on a camera stream to the toddlers bedroom when they're being too quiet.
lewis.hedrick: That is really one of the main uses for the tablet is to be able to turn on camera streams. Still working on ways to do this using BlueIris and Lenovo smart display (google). Haven't come up with a great solution yet.
Pretty easy with blue iris, just point to the stream in the dashboard.
Yeah the Lenovo Smart Display isn't a full google home device. It does not have a browser. I might be thinking too big here but was trying to figure out how to show on this display or pop it up when motion was discovered.
I am also test driving HE to decide whether to switch from Vera. Vera users have no option to change; the questions are when and to what. My Veraplus is, and has been for four years, working perfectly. Most apps did what I needed and I filled in the omissions with Lua code. Although I am experienced when it comes to automation, I am certainly open to new methods.
I could make an extensive list of the problems I have encountered with HE, but I have only begun the test drive. What I can say at this point is I am disappointed with the lack of updated and current (as of a certain firmware version) documentation. Like Vera, Hubitat relies on the online forum as the sole help guide. I suppose that works, but a lot of time is spent searching for answers. At one time experienced Vera users wrote step-by-step guides that were very helpful in both basic and advanced usage. For me, the Lua programming guides were fantastic. Those guides were listed in separate section on the original Vera forum. I know it takes time, but I ask of the Hubitat community to consider creating similar guides (or videos.) When you find something that works, document it with a few screen shots and instructions.
Sorry about your troubles - You should post that list (as others have done)... usually people here are willing to help. Just remember to have some patience - everybody is coming at this with different experiences and use-cases.
Yes I think Hubitat, Inc IS leaning heavily on the community for support and instruction but that doesn't mean anyone should expect members to just donate their free time. I enjoy participating in order to gain knowledge and to help people. I believe this is one of the more robust platforms out there with a great "synergy" between community and company - something SmartThings had early on but is now losing.
I have a bunch of bookmarks of things I want to remember but in general searching these forums for answers is fairly easy especially if you have some technical know-how - which if you are futzing with Lua scripts you probably have. HE uses Groovy..
I am not here to excuse poor documentation though, if there is any - and I haven't had the need to check in a while then that's on Hubitat, Inc. Of course you might consider reporting which docs you found to be inadequate so they could update/fix them.
For the record, I'm the guy who wrote MiCasaVerde's (founding company of the Vera line of controllers) WIKI. In return, they gave me $100 off my first Vera hub. Sadly, those docs quickly fell out of sync with current hardware and firmware, but after several years of neglect, at least things got updated for UI7 (current EOL f/w for Vera).
I came to Hubitat recently, thinking surely their documentation system would at least parallel if not exceed that of ezlo (current owner of Vera), but sadly that seems not to be the case. It's woefully underdeveloped, IMHO.
And to make matters even worse, the guys in charge – who, to be fair, do acknowledge shortcomings – mostly reject suggestions that they put effort into improving things like the Docs, Bug reporting system, or even the controller UI. Instead - as you said - there is great reliance on the Forum for finding/providing solutions.
It's unsustainable, to be frank. And unless you know exactly what you're looking for (as if by magic you somehow know what you don't know), it's an uphill battle.
On the plus side, the HE is light years ahead of Vera Plus in terms of usability and reliability, so welcome aboard!!
Okay I have not seen this personally but of course it doesn't mean it's not true - if you have any links to comments made by the staff that might provide some insight as to what you are getting at.. would be helpful.
Since Hubitat, Inc is a relatively small company I suspect the resources just aren't there to do everything they want all at once so they target the most critical areas first.. and of course customer support is always a huge (but necessary) time-suck. I will say the pace of updates is quite rapid and things have been constantly improving.
I respectfully disagree with this.
If someone can't articulate the issue even in vague terms how could anyone possibly help? There is now enough online information available in these forums that even being a little obtuse with your search terms should get you close to what you need. It does for me - type in a device name, or "hub issues" (for example) and results appear - may have to dig a little further but that's the nature of the beast. Otherwise simply posting a question usually gets a quick response.
This all doesn't seem so bad to me.. but maybe it's not quite what someone would be expecting coming from a different platform - I guess I can see that. I know I used to rely heavily on the SmartThings docs and forums.. neither of which were perfect but certainly navigable.
I do agree that relying on this community for client support if that is what they are actually doing is ultimately unsustainable... and there should always be decent docs. But of course none of that is anyone in the community's responsibility at all.
So, in brief, you do agree with me. Maybe I just overstated where I was coming from.
EXAMPLE: Earlier today, someone asked for help troubleshooting a problem using variable references in Rule Machine. He was placing the variable names in curly brackets and they were not parsing correctly.
SOLUTION: Put the names inside percent signs (%) instead.
ISSUE: I knew the answer, but no amount of searching in Docs would have turned that up for him. It was pure luck that I happened to read his post and happened to know the answer.
WHAT THE DOCS SAY: After clicking "Documentation" (in upper-right corner of this page), then diving into "Apps" ► "Rule Machine" (5.0) ► Hub Variables, there is zero mention of referencing-by-name.
WHERE THE ANSWER ACTUALLY LIVES: Under Docs ► "Apps" ► "Notifications" ► "Text Messages" ► "Variables" ► reference. Again, only a lucky person would find this answer easily.
As for my assertion that the guys upstairs aren't listening -- I know they are!! -- but I'll let the many Forum replies (like us begging for a formalized Bug Triage System) that end with "We don't have time or resources for that" stand for themselves. I'm not ascribing it to a lack of will or ability on their part; only a constant pushback since the Forum happens to be working as well as it does, however unsustainably longer-term.
I hadn't intended to hurt anyone's feelings or go on a rant (sorry).
No offense taken!
I thought you were talking about the community search for which there would likely be info available is all I meant, I usually start my journey there,,so many experienced people post.
I don’t expect forum users to do anything – they are not employed with Hubitat. My suggestion is that forum users consider creating a post when they learn how to do a task, not “only” when they have a problem. Yes, I know some have, but as with most technology forums, posts often begin with “I can’t do this…” or similar. That’s my plan as I gain HE knowledge.
From an outsider’s viewpoint, the lack of documentation is concerning. I learned from my experience with Vera that it is difficult for an automation company to succeed by selling only hubs. If I didn’t have extensive IT background, I would have given up on Hubitat after a few hours.
@LibraSun, thank you for helping me with Vera over the past four years!
Spot on with “you don’t know what you don't know.” As a programmer, network administrator, and IT instructor for my entire career, that phrase was my foundation when interacting with users and students. That phrase is true in all aspects of life.
When a technology company doesn’t produce documentation, it’s akin to a clothing company not advertising. Need to spend money to make money (or more accurately, invest in resources to produce more resources.)
I have high expectations for HE. I could setup Home Assistant on my Raspberry Pi, but I shouldn’t have to spend that amount time dealing with an operating system, docker, etc, etc, etc. just to flip a light on at 10:00pm.
I think you'll be very happy with Hubitat. Got mine just a couple of months ago, and was able to do in an afternoon what had required months and years of careful grooming back on Vera. Remember how even basic tasks like renaming a device meant Vera would become inoperable for 30-60 seconds and force a restart of the Luup engine? HA HA!!
Not here. Love how HE just "works" and nothing crazy happens (like all your devices mysteriously renumbering themselves and breaking all your Scenes). This is the life.
Arguably it's not the lack of docs - it's how to reference them as @LibraSun alluded to - the answer was there but not in the expected place. Hubitat's documentation seems to be a mess as they pointed out.
Really? Even following the excellent online tutorials from the Hubitat website? One can certainly install some devices and set up basic routines like lighting etc with little difficulty.. of course getting into more advanced topics I can totally see difficulties and frustrations you are pointing out.
Yes having a much better dev reference site would be fantastic but I'm guessing it's not really a priority for them right now. Whether that's a good business move or not is not my call...
The good news for us end users is even IF Hubitat, Inc were to go away tomorrow it would not change anything in our setup or day to day operations and this would last until our hardware gave out.
I’ll disagree with that statement. I have IP cameras that the vendor no longer provides a firmware update. There are most likely security problems with the current firmware version. Every system has flaws and needs to be patched.
My current system – Vera – is basically defunct. Current owner Ezlo ended the product line and not replaced it with a suitable replacement from what I have read. After years of building an automation system, I now rely on it. Five years ago when I investigated which automation system to install, Vera fit my requirements. At the time, I saw no indication they would make such major changes. “If” became “When.” I do not want to wait until the controller stops working or support ends (including the forum).
We will have to agree to disagree then!
Maybe it's an experience thing - I've been messing with HE for a few years now so am definitely comfortable and confident with my system. I could stop now and things would just run barring a hardware failure - I do have a few hardware backups handy just in case.
The one issue would be not being able to incorporate newer devices as they come out - things like Matter etc.. however my system uses Node-RED so I can hook into pretty much any system with an API or MQTT.. also if I was desperate and had get rid of my HE hubs for whatever reason I could shift over to Home Assistant (for example) and my rules would be pretty much stay the same barring some tweaks - of course it would indeed be a big PITA but certainly doable.
My point is that our hubs functioning properly are not contingent on Hubitat, Inc existing unlike most others (Amazon, Google, etc). You would lose some niceties like the phone app and remote admin stuff but thats about it.
Surely there are system bugs but the platform is mature enough now that any critical showstoppers have either been discovered and fixed or can be mitigated via custom apps/drivers etc. You also have the option of NOT applying firmware updates if you don't want to.. which is nice.
Everyone has their own opinion. I did exactly this gave up on Vera after only 8 months of purchasing their most expensive hub VeraSecure. I was not going to read literally 18 pages of documentation just to figure out how to write a simple rule in PLEG.
The only thing that kept me happy during my final 18 months in the Vera ecosystem was @toggledbits ' Reactor for Vera and Reactor Multi-Hub (for Hubitat / Vera / others). With it, I was able to migrate all Scenes away from Vera, retire a whole bunch of third-party plug-ins (Vera's name for apps), as well as most of my Modes settings.
That made the ultimate transition over to my new Hubitat controller a piece of cake! If only Rule Machine did half the things Reactor can do in terms of variables, logic, math, IF/THEN, data substitution, list iteration, HTTP response parsing, realtime status updates, etc. (Think of Reactor as a more power webCoRE-like app running on its own Linux box or Docker container within an RPi or Synology NAS).
Reactor was the best possible stepping stone away from Vera, and I'm totally grateful for it. Indeed, without it, I may have stuck around until all of my Vera boxes literally died from exhaustion.
