I recently moved and have a new router and wifi network. I am able to connect to my hub only through the remote admin connection. It wont connect locally. Everything is working perfectly.
How can i update the hubs IP or do something so that it connects via the local connection?
By default the HUB is setup for DHCP so you'll need to get into your router to figure out what IP address it has now. With a new router, the address has changed. Most routers should list the mac address of each device, compare it with the mac on the Hubitat to find it. Once you find it you'll also want to setup a dhcp reservation in the router so it gives out that same address forever.
If you can get to it using the remote admin option, it already has an IP on your network, you just need to discover it. Multiple ways of doing this, but I generally go into the router and bring up the attached devices list and look for it there.
So that’s the thing. I had an orbi router and set the Hubitat to a static IP. But I moved and get free WiFi. So I have an IoGear wireless Ethernet adapter that the Hubitat is plugged into.
Gotcha, so you have no control over the router. Well since you have remote access, do this. Log into your hub remotely, go to settings, and then Hub Details. Should show you the local IP.
