Motion Sensor placement application
Having just entered the area of home automation, I think there should be applications where you can model your rooms, and then create your motion sensors, so that you can visualize the best placement of sensors. Almost like apps for garden sprinkler placement...infact, perhaps sprinkler apps might be used in a pinch for motion sensor placement :smiley:
Unlike video cams, setting up motion sensors seems to be working in the blind. If they have cool of times, then how do I even test what coverage am I getting.
Such an application would have to be 3D as most sensors have angle coverage and vertical coverage.
The motion sensor I actually spend time setting up had a "test" mode that would flash the red LED when movement was detected. One could walk around, duck down etc and see if it was detected.
I have sonoff sensor and not sure if it has any similar test mode(without needing sonoff hub).
