I found that some motion events didn't trigger the apps, after digging into it, I found that the events were logged but not saved as an "event" and thus not triggering any actions. There are 17 log entries, while only 2 event entries.
Below are the logs between 12am and 7:30am:
dev:865 2023-09-11 07:30:04.564 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 07:29:30.815 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 07:23:35.694 AMinfoHallway Motion Sensor battery is 100%
dev:865 2023-09-11 07:20:04.825 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 07:19:30.090 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 07:16:13.160 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 07:15:36.316 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 07:14:13.198 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 07:13:33.223 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 07:01:31.021 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 07:00:56.629 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 06:59:15.197 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 06:58:38.195 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 04:58:51.644 AMinfoHallway Motion Sensor is inactive
dev:865 2023-09-11 04:58:05.278 AMinfoHallway Motion Sensor is active
dev:865 2023-09-11 02:33:53.949 AMinfoHallway Motion Sensor temperature is 76.25°F
dev:865 2023-09-11 02:33:51.363 AMinfoHallway Motion Sensor temperature is 76.25°F
And below are all the events between the same time window from the "Events" tab:
battery 100 % Hallway Motion Sensor battery is 100% DEVICE Hallway Motion Sensor Maker API - Homebridge (eventHandler) 2023-09-11 07:23:35.696 AM CDT
temperature 76.25 °F Hallway Motion Sensor temperature is 76.25°F DEVICE Hallway Motion Sensor Maker API - Homebridge (eventHandler) 2023-09-11 02:33:51.370 AM CDT
