Say I want to leave a light on for 5 minutes after motion stops. Should I use motion retrigger in Device, or set the 5 minutes duration in a rule?
I changed several devices, from, say, 20 seconds, to 5 minutes, and the rule to zero because I thought the log was getting too busy. But maybe that doesn't make any difference.
Several times the light didn't trigger on motion (not seen in log), for whatever reason, and I had to wait 5 minutes before I could activate the motion sensor once again, whereupon it lit. So I can see this being a reason to use a rule vs. device setting.
