I used to have a motion rule set up to turn on the downstairs lights automatically when you use the stairs. The motion detector has since been moved and well the wife never trusted the automatic shut off of the lights because every time she went to check on them, she tripped the motion sensor. BUT that's a different story =]
Anyways I removed the motion app but now the lights turn off right away when you turn them on.
It's not in use by the app anymore. The logging doesn't show what turned off the light either.
dev:972021-08-26 12:41:24.597 pm infoMotion Sensor: motion is active
dev:372021-08-26 12:41:20.287 pm debugdescMap:[raw:CAE501000808000020FF, dni:CAE5, endpoint:01, cluster:0008, size:08, attrId:0000, encoding:20, command:0A, value:FF, clusterInt:8, attrInt:0]
dev:382021-08-26 12:41:20.277 pm debugdescMap:[raw:556E01000808000020FF, dni:556E, endpoint:01, cluster:0008, size:08, attrId:0000, encoding:20, command:0A, value:FF, clusterInt:8, attrInt:0]
dev:372021-08-26 12:41:18.499 pm debugdescMap:[raw:catchall: 0104 0006 01 01 0040 00 CAE5 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CAE5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:372021-08-26 12:41:17.173 pm infoDownstairs Light 1 was turned off
dev:372021-08-26 12:41:17.169 pm debugdescMap:[raw:CAE50100060800001000, dni:CAE5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:372021-08-26 12:41:16.877 pm infoDownstairs Light 1 was turned on
dev:372021-08-26 12:41:16.872 pm debugdescMap:[raw:CAE50100060800001001, dni:CAE5, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:372021-08-26 12:41:15.493 pm debugdescMap:[raw:catchall: 0104 0006 01 01 0040 00 CAE5 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CAE5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
I cannot figure this out. I tried to remove the bulbs and re-add them but it recognizes them as previously added.
