Motion Lighting Using Same Sensor
Will the following turn off the selected switches after five minutes of no motion? i.e. is the five minute timer cancelled when motion is detected or is the motion property of the sensor checked at the end of the timer?
I assume that since you are asking the question, it didn’t work for you?
My recommendation would be to use Basic Rules for something like this.
Okay, but the same question applies, "is the five minute timer cancelled when motion is detected or is the motion property of the sensor checked at the end of the timer?"
No, not the way you have it. That's not how to set up the Basic Rule. Use "Motion has stopped and stayed inactive for..."
Where is "When a ..." and "Motion has stopped and stayed inactive ..."
Is that Motion Lighting, Simple Automation Rules, or Rule Machine?
Basic Rule
Wow, I've been using Hubitat for 17 months and didn't even know Basic Rules existed.
Thank you.
