Would it be possible to add an option to set different levels for 2 different dimmers in ML? One example is in my Master bath I have recessed lights and vanity lights but the vanity lights will only dim down to 25%, where the recessed would go down to 3%. In this case I would want both to come on by motion but at different levels depending on current mode. I know I can do this with rule machine, but it seemed like a simple option that wouldn't complicate ML too much.
You can do this by using a Scene and setting the devices to different levels there. You can set Scenes per mode like you can dimmers.
I always forget about Scenes, that should get around this issue.
