Just came across this post as it addresses a similar scenario that I am currently looking at. I have motion lighting in a bathroom that I would like to "jump-start" with a door sensor. Once the door contacts detects a door-open, I want the lights to be triggered and then have the motion sensor routine take over. I can't seem to get this to work, the code works fine for the motion sensor alone but once I add the variable for the door contact, the light simply stays on. Any advice on what I might do wrong here?
I use motion lighting which is faster than RM. I use this small app that @bravenel wrote to make a contact sensor appear as a contact-motion sensor which can be incorporated with actual motion sensors into the built-in Zone Motion app. I use the virtual motion sensor from that as the motion sensor for Motion Lighting. It may sound complex, but it is lightning fast. Lights come on well before I have the door all of the way open.
Thanks, I just played with that a bit and it seems to work well. Having said that, there is one issue that I am not sure how to address. When I enter the room, the lights turn on very quickly and the motion sensor keeps them on. Since this is a bathroom, whoever goes in there is likely to close the door once inside
Now, when you turn off the lights in the room before you open the door, the contact-motion sensor will turn them right back on. It would be great if there was a timer function that keeps the motion lighting app from reactivating for a few seconds once the lights are turned off manually.
Never mind - I was able to accomplish the delay with a virtual switch that turns on for 5 seconds once the lights are turned off - works great now.
Ken I seem to have an issue. I thought I followed your directions but the lights are not coming on in my garage when I open the door. I have a contact sensor on the door and a motion detector in the garage.
The code for the user app was added to my HE and the interior garage door was added as the contact sensor. Named: Garage Door Contact Motion
The built in Zone Motion Controllers app was added. Created a Zone named Garage Motion Zone. Setup as a trigger activated zone with the motion sensors Garage Door Contact Motion and Garage Motion Sensor. The activation window is 5 seconds with a timeout of 5 minutes.
The Motion Lighting App us very simple. The motion trigger is mZone - Garage Motion Zone, turns on the garage switch, and delays for 1 minute.
Where did I go wrong?
Set this up as Motion Aggregation. Also, don't use a long timeout in the Zone controller, I just use 1 or 2 minutes. I set the real timer in Motion Lighting.
So it seems like it's working. Thank you.
Hi all, I am doing something wrong and Iโm sure itโs simple. The scenario is this:
I want the lights to turn on for my attic when I open the attic stairs (pull down), then turn off after 5 min when I close it up.
Right now I can turn it on when I pull down from the contact sensor, but when I close it it turns off immediately. I have it set for a 5 min delay and have tried all the different modes as well with that setting.
What am I doing wrong?
Eric
Can we please see a screenshot of how you setup the automation? And why are you using Motion Lighting (the subject of this thread)? It would seem that Simple Automation would be a better choice since no motion sensor is involved.
Thanks for responding. The reason Iโm using this is because I donโt know any better and it was listed under Lighting. Iโm fairly new to Hubitat (came from ST).
Hope these shots help.
I believe if you switch to Simple Automation, it can easily do what you want.
Simple Automation Rules - Hubitat Documentation
Welcome to the Hubitat Community! Post back in a new thread if you have difficulty.
Ty will try!
Worked perfect ty!
