Motion lighting import log observation
I'm trying to switch from existing ML to RL setup. I imported one of my existing Motion Lighting setups...then paused the ML version and resumed the RL version. While monitoring the logs to see how it tracks in Room Lighting, I noticed the paused Motion Lighting app still spits out <Device> turned on, and <Device> turned off entries in the logs. Not a major concern, but thought I'd report for any devs that may care (not sure who to tag).
i expect it will be Bruce, but personally am still interested to understand a little more...
You're right that the concern is limited, but the fact that the code driving logging still running doesn't fill us with a sense of confidence....
For those that look at this stuff... I expect they will want three things...
  • HE platform version
  • ML and RL setup screenshots
  • Screenshots of Logs to show what you are describing
Great points
Platform version: 2.3.4.134
ML and RL Screenshots
Log Screenshot
App 457 is the paused ML app, but the activation/turn off of App 1851 (the RL app) seems to lead to the log entries. I realize I can turn logging off in the paused one (or remove it), but it seemed like an unintended behavior.
@bravenel
Simply disable app 457.
The grayed out X just right of the grid displays the Disable Column:
Screenshot 2023-01-25 at 8.34.38 PM
Then check the box to disable.
Screenshot 2023-01-25 at 8.34.26 PM
I'll do that.
However, should the paused app be reporting any logs? The scenario seemed odd that pausing didn't stop them all (it does stop many others that ML used to generate).
