V: 2.2.3.148. This just started happening the past few versions.
Using a Zooz 4-in-1 sensor with Zooz27 dimmer. I have motion lighting set to turn on whenever there is motion. I see the event. The first one every morning never works (most needed time :)), after i physically turn it on the motion on works the rest of the day.
That's my master bath rules. I'm going to guess you need to add the switches to turn on and off to the options for activate, disable and enables lights-on and to the options for additional sensors, lights-off and off options.
You shouldn't need the switches to turn on/off in the ML app. Instead of looking at ML app events, enable logs and look at them as they are more verbose and will provide more information. Look at logs for ML app, motion sensor, and light.
