I have a motion lighting rule, with two variables checked under "Boolean variables to disable turning on when true." I find that when both are true, the lighting is appropriately disabled. But when only one is true, the lights turn on.
Is this the intended behavior--that is, all need to be true to disable? Is there a way to say "any of the following is true" disables turning on? (As a kludgy workaround, I could make a third variable with a rule to set it to true if either of the control variables is true, but that's not ideal.)
