Motion lighting between two times not been enforced
My bedroom rule kindly turned our lights on at 5:30am as house went into day mode. But there is a restriction on time for this motion lighting rule.
Time is correct on Hub and no other light rule for this light . Any idea why it turned on outside the times ?
bug? could it be my hub mesh is noisy due to my dodgy nue dimmers that could be causing it to not run rules correctly? - my other rules seem to be ok
thank you
Turn on logging. I've never seen it do this, and my bedroom has a time restriction also.
ok cool shall do. I have a feeling it could be lifx had a blip on scene change which occured at same time. i have the ignore power setting which has worked for years. but tested it after and it didn't turn it on when they were off in app
ok this is on me. I duped the iftt rule for activating scene and missed putting the ignore power in there.
thank you (wifey was not impressed....)
