I created an automation (a week ago) with an Iris Motion sensor and My Lutron Dimmer in the Hallway.
When motion turn on.
After 1 minute turn off.
Works great.
Today I created to exact same automation with an Iris motion sensor and my GE zwave dimmer in the bathroom.
For some reason it does not work.
If I edit the original automation and replace the sensor and light with the bathroom…it works fine…huh?
If I edit the automation I created today and put the hallway devices…nogo.
So even though they are both configured the exact same way, the automation I created a week ago works with all devices…the one I created today works with nothing.
I know this has got to be something silly but I can’t for the life of me figure it out.
BTW…all device are controllable and are reporting motion and status changes in the logs.
Oh…and I deleted and recreated the bathroom automation with no change in result. I don’t want to remove the hallway automation for fear of not getting anything working again.
I didn’t even realize that App existed! I just created a “Motion Lighting Apps” automation using a motion sensor and it was able to turn on a light without any issue. So, at least we know it is not the newest firmware that broke the ability to create at least the first automation.
I’ll try adding a second one to see if it makes a difference…
The only things I’ve had not work so far are devices with complicated apis and I’m a total noob when it comes to troubleshooting apis. The rules have worked fine for me, but I’ve only added a couple Button controller and Rule Machine automations.
I added a second one with the same results as @stephack. The first “Motion Lighting Apps” automation continues to work, even if I change the motion sensor being used as a trigger. The second automation never works. Looks like a bug for @bravenel to squash!
[UPDATE] I have removed all of the MLA automations and tried to create a new one…no joy. I removed the “Motion Lighting Apps” app, and then reinstalled it and created a simple automation…still no joy.
This is all very odd. We will dig into it. I have over 25 of these in use. I cannot for see how one child app would work and the next one not. That screen shot above is also very odd, as it is showing the parent app, not the child.
