When assigning a button to a function in the motion lighting app, please consider adding an option to select whether it triggers when the button is pushed or held. In particular, I'd like to be able to configure a button to toggle the lights on and off when pushed, and to (temporarily) pause/disable the motion lighting rule when the same button is held.
While we consider the feature request, an interim solution is as follows: Create a virtual switch, and a rule that toggles it on/off from the button held. Then use that switch in Motion Lighting to both disable on and disable off.
Thanks, I’ll give that a try
