I just installed a new Zooz Zen27 dimmer switch for my side door, which works perfectly, turns on and off manually and via dashboard. I then ordered a Zooz ZSE29 Outdoor Motion sensor and installed over my side door. I want to turn on the side door light when motion is sensed by the motion detector. I have setup the Motion Light App, but haven't had any success in getting the side light to come on when motion detected.
Below are a few screen shots of the app..... any help on how to debug this would be appreciated....
Obviously good advice, i enabled logging and walked under the sensor.... nothing appeared in the log. i'm quite sure the motion detector paired fine as it shows in my list of devices. Any advice on how to test the motion detector?
That appears to have fixed it, i am still having a minor problem with the motion detector ...it works fine in test mode, but when i move it into normal mode it doesn't recognize motion.....i have setup a ticket with Zooz on this as it doesn't appear to be a hub issue.
