More ways for LG to keep up with what's going on in your life
I am appalled that Apple thought this was a good idea after the GN exposé.
I'm not shocked in the least. Apple practically invented the concept that they own your devices and maintain complete control over what you can do with them.
Me too, though it’s possible they’ve been working on things for longer than details for either have been out in the public…
But I’m really hoping they are Matter over Thread devices I can use without anything LG at all, like they are basically just making the hardware…or maybe Matter over WiFi if someone can assure me the device can’t use that same WiFi for other purposes, though that seems quite likely (and even for Thread seems possible given it’s all IP by the time it gets used by humans, but I’m hoping that’s harder or impossible with just that). :grimacing:
LG actually has produced Matter via Thread sensors and devices in their home market for a little bit (see Matter Product Database Search | Matter Alpha). It wouldn't surprise me if this new collaboration is slightly different than LG's previous devices, but it could also just be LG bringing their preexisting portfolio outside of Korea and getting special placement in the Apple store.
Matter-over-thread devices can still access the internet, and it's probably a lot harder to actually block that with a firewall without breaking Matter than it would be to block a standard wifi connected device.
related:
Apple’s approach is usually about restricting/forcing many elements of the user experience. Yes, it can be very annoying/a turn off (especially when it’s a family member that needs help with a Mac that usually “just works”).
But how is that related to what LG’s been accused of doing, essentially spying on customers?
Is it?
The article says he decided not to waste his own time by drilling down into it further (seems like a wise choice), but the ridiculous amount of data it was transmitting remained within his LAN.
His assumption was that it was probably a poorly designed/programmed device, not that it was spying on him and reporting back to Breville.
I guess I took that from GN videos showing LG exec's talking about "Owning the glass", meaning they essentially feel like they can justify doing whatever they want becaues it's "their" tech, now ours.. It just feels like a logical extension of Apple's own "walled garden" and locked down approach to tech. They already control basically all other aspects of their gadgets, and it feels like partnering with LG reinforces that they will probably be using their tech to spy on their users going forward. At this point, why would anybody think they wouldn't??
Looks like there is a little bit more to this story:
It seems like Apple is developing "second party" partnerships with another brand besides LG. Interesting that Apple would go this direction. I wonder what additional benefits someone would receive from purchasing a second-party device versus someone else's matter version.
I suppose my question is really how likely, possible, or attested-in-real-life this is. For example, if used on Apple Home as Matter over Thread, and Apple only subscribes to and sends the clusters/attributes, events, etc. it needs, I don't see how a manufacturer could use it for nefarious purposes very easily, perhaps at all (compared to Wi-Fi where the device doesn't need a Thread border router that is typically part of your smart home system to communicate with Wi-Fi/Ethernet, where I assume the device might be able to use this same connection directly, including for purposes outside Matter).
I would be interested in reading more about this if anyone has any sources!
I have no evidence of Matter sending stuff to the home base, but it sure makes you wonder given the recent track record of LG. It also wouldn't be the first time some spyware was embedded into something without people noticing. So I won't say it never could happen...
I would be very hesitant to try or promote using this Apple/LG device just due to the trash reputation of LG at this moment.
The Matter part is irrelevant here. Thread uses IPv6 as its transport. The TBR routes IPv6, whether it's Matter traffic or something else. So it's possible in theory.
Whether the Thread device gets a routable IPv6 address and whether your home router would do something with it is another story and a little bit beyond me, admittedly.
Clanker information
Whether that traffic can reach the internet depends on the TBR and your home router:
  • No IPv6 on your LAN: the TBR gives the mesh a private ULA prefix (fd..). Devices can reach the LAN but have no internet route, unless the TBR also does NAT64, which Thread 1.3+ border routers can do to reach IPv4 hosts.
  • IPv6 on your LAN: the TBR can hand Thread devices a global prefix (from your router's advertisements or via DHCPv6 prefix delegation). Outbound traffic is then just routed, subject to your router's firewall, which typically allows anything outbound.
So it's possible in principle. In practice it's rare: most Thread devices are battery-powered, low-bandwidth and memory-constrained, and running TLS to a cloud endpoint is costly. I'm not aware of any documented case of a Thread device phoning home this way.
If you want to be sure, firewall the Thread prefixes at your router, or turn off NAT64/prefix delegation if your TBR lets you (OTBR does; Apple and Google hubs generally don't). Local Matter control keeps working either way.
Source: OpenThread Border Routing docs
That’s a lot of assumptions. You’re certainly entitled to your opinion but I’m still puzzled about why you feel as though this is the only plausible interpretation and no one else could conclude differently.
Yes
I said absolutely nothing of the sorts. At no point did I say there were no other interpretations or that no one could conclude differently. I said "Why would anybody think they wouldn't??", which in and of itself draws absolutely no concrete conclusions about Apple OR the validity of other conclusions.
I guess I misunderstood what you mean.
You seemed pretty convinced that it’s just a matter of time before Apple spies on its customers as if that’s the only reasonable conclusion to be made.
Since there’s no evidence of that and you’re making unsupportable conclusions based off assumptions as you’ve noted, we’ll agree to disagree.
:victory_hand:
If I'm being honest, yes, that is exactly what I believe will eventually happen, if it doesn't already.
No, again, I didn't call any other conclusions unreasonable.
But I would be happy to try to get into WHY I think Apple is likely to spy on you, if they don't already.
This seems like a pretty odd conclusion to draw, IMHO.
Apple has consistently been the one and only major technology computer to prioritize end-user privacy and data protection. Apple encrypts user data locally on user devices in a way that Apple itself does not have the ability to access it. Researcher after researcher have agreed that the Apple platform is the best for end user data security and privacy.
Contrast this to the Android and Windows platforms, where end-user data is the product mined by tech companies. Yes, these platforms offer more flexibility in terms of what the user is able to run on them. However, the lack of end-user data privacy is the major trade-off.
There are Pros and Cons to all of these platforms. For some users, data protection and privacy is the priority. For others, they are willing to sacrifice data privacy for the sake of additional flexibility.
This is the major reason that for ~25 years, my personal computers have either been Macs or run Linux. Same for my office/lab computers at work.
Yeah, I do get that. And while Android and Windows have slowly started integrating advertisements right into the OS, Apple hasn't done so yet. There are a lot of good aspects of Apple in regards to privacy.
However, I think there's signs that things are changing. Apple has recently started leasing their devices - which signifies, to me at least, the beginning of a shift towards the subscription model rather than outright device ownership. And the reason they'd move that direction is simple: it's $$.
Apple has an in-development AI product (Siri) that is leagues behind anything else, and maybe they wouldn't be completely opposed to utilizing Apple customer's data as training data like Meta, Google, Microsoft, X, OpenAI, Anthropic, etc all utilize their customer's data to train their models.
Personal data is perhaps the most lucrative and highly coveted information in basically ANY current industry. Look at all the biggest tech companies: X, Meta, Google, Microsoft - ALL of them collect and sell your personal data, they store it so they can analyze it and sell you more stuff, they use it to train their AIs. Personal data collection is practically everywhere. Target knows you by name and has cataloged every electronic device you carry with you into the store if it has a radio on it. So do Flock cameras. Palantir has been integrated into practically all major US government systems, potentially giving them unrestricted access to your personal medical and financial data for who knows what purpose.
We've already known that google assistant speakers always listen, we know that Android phones listen to conversations and then miraculously provide ads or search suggestions about things you recently talked about. We know that LG TV's spy on you. I know that Vizio does the same, and I would assume that ALL TV's made since 2020 also do. Even devices that you never think of, actively collect data about you.
Do you have a Subaru? Do you have the Subaru app on your phone or connect your car to Wifi for any reason? If so, it transmits a complete log of your trips, driving habits, locations, engine codes, etc to Subaru. Why? Who the heck knows..
So my main reason for thinking that Apple will probably spy on Apple users eventually, if they don't already, is this: Why wouldn't they? 80% of the public wouldn't know anyway, 95% of them couldn't do anything about it if they did know about it.... and obviously all the $$$ they stand to get from selling either the data itself, or using it to sell their users more things. I just can't think of a good reason why Apple wouldn't, at this point.
Here's a link that details all of the personal data that Apple tells you they keep on you. Legal - Apple Privacy Policy - Apple
But obviously, this is all just what I think about the situation. Anybody else is certainly allowed to hold whatever opinion they want. I'm even willing to listen to and accept alternate takes on the matter, but I admit it would probably take a lot of very well thought out debate to change my mind on the issue.
