^ this...
Thank you.
I live in Singapore - the highest population density in the world. To accommodate so many people psf, buildings are made of reinforced concrete.
I find that there is very little distance allowed between a HUE Sensor and the HE Hub.
For example, I have the HUE Hub 10m away down the corridor. I have 2 sensors in the same bathroom. The one by the door can be refreshed, the one 1.5m further away in the shower cannot.
- Bring the shower sensor closer to the HE Hub and it works fine.
- Delete the device, remove its battery and hard reset it works fine - from the desk. Replace it on its mount in the shower it cannot reach.
The device is mounted next to a Philips HUE Aphelion DL which is on a separate mesh to the HUE Bridge. Possibly this is adding to the interference.
Question: any repeaters available that will help range for the HUE Sensor?
Well any repeater will help with your devices Hubitat.
I'm not following your setup, you have hue sensors paired to hubitat?, and you have no zigbee repeaters?
If that's the case simply adding a single repeater between the hub and the sensors in question will probably fix it.
