Monoprice / Vision Motion detected as Zooz 4 in 1
I just "installed" a Monoprice 15271 Motion/Temperature sensor. This is similar/same(?) as the Vision ZP3102.
When discovered by HE the Zooz 4 in 1 sensor driver was chosen.
Monoprice Mfg ID = 0x109
Vision Mfg ID = 0x109
Zooz Mfgf ID = 0x27A
Why did HE think this device was a Zooz?
Also is there a better driver for the Monoprice / Vision?
John
The original Zooz 4-in-1 Sensor had an identical fingerprint as the Monoprice 4-in-1 Sensor, but Zooz changed the manufacturer to 0x27A in their 16.9 firmware.
What's the deviceId of that Monoprice Motion/Temp sensor? It should be different then the Monoprice 4-in-1 sensor, which is 2101, and if it's different then I have no idea why Hubitat assigned it that driver.
Hi Kevin, Thanks for the response.
The device data is below. I was surprised not to find an ST driver for the Monoprice/Vision device. Are you aware of one?
John
  • deviceType: 8194
  • zwaveSecurePairingComplete: true
  • driverDetails:
    Zooz 4-in-1 Sensor
    Version 1.0.2
    Supported Devices: ZSE40
  • inClusters: 0x5E,0x86,0x72,0x5A,0x85,0x59,0x73,0x80,0x71,0x31,0x70,0x84,0x7A,0x98
  • firmwareVersion: 8.2
  • deviceId: 517
  • manufacturer: 265
I just paired one of these a couple of days ago. I too would be interested in the appropriate driver to use. Right now I've got it set at "Generic Z-Wave Motion Sensor" and it works as such, but it would certainly be helpful if I could utilize the temperature data as well. (By the way, mine was purchased a few years ago, so it might be a slightly different model.)
The following is what I came up with upon discovery:
Manufacturer:0109Product Name:Generic Z-Wave Motion SensorModel Number:Unknown Part NumberdeviceTypeId:66
more...
nodeId:15
deviceId:0203
manufacturer:0109
deviceType:2002
inClusters:0x71,0x85,0x80,0x72,0x30,0x86,0x31,0x70,0x84
outClusters:null
( @mike.maxwell : just FYI )
Found this thread searching for info on the Monoprice 4in1 sensor (Model15902).
I also notice it too adds as the ZooZ 4in1.
Issue is I can't change the Motion Retrigger time and it is stuck at a 15 min default.
Any suggestions?
For mine I found this in the manual:
In the device page I changed the driver to Basic Z-Wave tool (you might need to download it)
I changed parameter 1 to 5 (for 5 minutes)
I believe in the Z-Wave tool there are 3 entries:
from top to bottom
Parameter number
number of bytes
new value.
I used
1
1
5
Then go back to the original driver. Note if you press configure in the driver you will / may undo the changes you made with the Z-Wave tool.
Good luck
Was able to change the parameter to 1 minute. And it seems to work but in testing the motion sensor, I'm not a fan of the Monoprice. I have been testing it with a log file running and it periodically won't wake up on the first sign of motion. I'll play with the sensitivity but I only give these sensor 1.5 stars!
