Monoprice Tilt sensor factory Reset
Does anyone know how to reset the monoprice sensor? I wasn’t able to exclude them from another hub.
I read somewhere to remove the battery for 2 minutes, put hub in exclude mode and re-insert battery. Probably should be as close to hub as possible.
The old hub is dead.
You can use the new hub as well.
If you are talking about the Garage Door Sensor (11987) it does not have a true reset but usually can be excluded even with a new/different hub using the exclusion process.
  1. Remove the sensor cover
  2. Put hub/controller into exclusion mode
  3. Press/hold the program/tamper switch on the sensor for ~1 second
Here is a link to the manual also:
Ok, I will try!
Thank you!!
Thank you!!
