Monoprice Single Relay 11989
I am migrating to a C7 after my C4 crashed and wont come back online. I cannot figure out which driver to use for my Monoprice Single Relay 11989 devices. I have a few of those and a bunch of the dual relays. I can get them to pair (it isn't easy) and the duals work fine with the Generic Z-Wave Plus MultiSwitch, but none of the drivers I have tried work with the single relay. Anybody have them working and if so, which driver are you using?
I was finally able to get my c4 back online. The correct driver is Generic Z-Wave Relay, but in order to get it to actually work I had to press the program button for 3 seconds to program the switch.
These are finicky devices and have to be a couple feet from the hub/minimote/zstick in order to pair or exclude, but they do the job once they are paired and programmed.
