Monoprice motion & temp sensor stuck active
after update stopped working stuck in active I have tried repair and z wave repair
Check the device page and make sure you're still on the generic driver. Then click configure and see if that'll snap it out of the funk.
Tried that earlier with no luck tried again still no luck. Everything else works like temp and battery but stuck active for motion. Thanks for your help.
I have these ... try removing the battery and putting it back in.
Was about try that and it started working again. Thank you again for the help.
