Looks like this is lightly documented at PIR Sensor and there is a parameter for sensitivity. I used @mike.maxwell 's tool to make it less sensitive and see how it performs
Hopefully that works for you! I lost the manual for mine and also tried to find the parameters by searching for the VisionTek manuals, and I think parameters 1 and 3 were reversed, so the one that said it was timeout was really sensitivity, and vice versa. Unfortunately, I cannot find that manual anymore, and my device is sleeping (and mounted on the ceiling where it would be a pain to wake it up), so I can't reliably do a ConfigurationGet on it right now to see what I actually did. That manual appears different from the one I remember, however, so maybe it's correct. Just one thing to consider in case it doesn't seem to work for you!
Hope so! I tried a get param and they values matched the default values on the spec sheet so I hope they are correct. I also ordered a couple of Hue sensors and I will probably dismiss the Monoprice ones anyway
Yeah, I'm not a huge fan of these. After trying a couple, I returned all the ones that I could (I bought a few at an attractive price, once hoping to go all Z-Wave when I switched from SmartThings and discovered that nothing else at the time did Zigbee quite as well--but Hubitat was released just months later). They're big and slow,so I've put mine outside, still reasonably protected, where I don't care about speed (or the occasional miss, which they also seem to do) ... and if it eventually goes bad, I'm OK with that.
