I have setup 4 modes, which should switch based on sunset/sunrise, but only 2 modes are used:
What am I doing wrong?
Is your location correct in your hub? What does it show under settings, location/modes for Sunset?
Try entering 0 minutes for the offset time.
It was already set to 0:
I have now set it to 30 minutes after sunset. Will check if it works tonight.
Changed the offset to 30 minutes for Night mode fixed it:
I suspect that only 0 offset does not work, which I suspect is a bug... not a feature
Does it work if you remove the 0 and leave it blank?
Will try and report tomorrow
