Mode Manager parse exception
[This was put in Integration, should have been here, don't know how to move it]
I've had automations fail in the last week+ and could not find the reason but just last night noticed that the Mode did not change.
Running a C4 hub with the latest update (2.3.2.139).
When I click on Mode manager I get this exception:
app:2042022-07-18 09:08:16.966 am errorjava.text.ParseException: Unparseable date: "7:00" on line 1010 (method mainPage)
I have not changed the mode date/time in a long time (years) so not sure why this happened, but more importantly no idea how to fix it.
You can use the edit (pencil) icon next to your topic (thread) name to move a post to a new category:
If your account is too new, it's possible you may not have these permissions yet--but that doesn't look like it should be the case for you. At this point, we can just ask a moderator to delete the "old" topic.
I noticed that I can look at the Modes setting (gear icon) when I get this error. I see this setting in the "Application State" properties box:
Value: Day: at 7:00 AM Night: at 10:00 PM Modes to ignore time changes: Away
I also see that I can export the settings as a Json file, I can't attach so I'll paste it below.
I've updated to the latest build (141) but still no go.
@bravenel and idea? Should I try to delete Mode Manager and import these settings?
(I didn't see anywhere to 'report a bug' so if there is let me know).
Thanks, here's the json:
{"deviceReplacements":{"134":{"deviceName":"AwayMode","deviceLabel":"Away Mode","deviceTypeName":"Virtual Switch","deviceTypeNamespace":"hubitat"}},"appReplacements":{"204":{"appTypeName":"Mode Manager","appTypeNamespace":"hubitat","appType":"sys","appName":"Mode Manager","appLabel":"Mode Manager <span style='color:green'>Day</span>","parentAppInstalledAppId":null,"parentAppTypeName":null,"parentAppTypeNamespace":null,"parentAppName":null,"parentAppLabel":null,"childApps":{},"singleInstance":true}},"appData":{"204":{"state":{"str":"Day: at 7:00 AM\\nNight: at 10:00 PM\\nModes to ignore time changes: Away\\n","updateIgnore":true,"later":{},"earlier":{},"shadowMode":"Day","strS":"Away: Away Mode ON\\nDay: Away Mode OFF\\n","strD":"","strB":"","clonedName":"Mode Manager <span style='color:green'>Day</span>","updated":true},"appSettings":[{"deviceList":null,"multiple":true,"name":"switchOffNight","type":"capability.switch","value":null},{"deviceList":null,"multiple":true,"name":"daysAway","type":"enum","value":null},{"deviceList":null,"multiple":true,"name":"ignoreModes","type":"enum","value":"[\\"Away\\"]"},{"deviceList":null,"multiple":false,"name":"atTime11Night","type":"time","value":"22:00"},{"deviceList":null,"multiple":false,"name":"time11Night","type":"enum","value":"A specific time"},{"deviceList":null,"multiple":false,"name":"atTime11Day","type":"time","value":"7:00"},{"deviceList":null,"multiple":true,"name":"daysDay","type":"enum","value":null},{"deviceList":null,"multiple":true,"name":"switchOnNight","type":"capability.switch","value":null},{"deviceList":null,"multiple":true,"name":"buttonAway","type":"capability.pushableButton","value":null},{"deviceList":{"134":"Away Mode"},"multiple":true,"name":"switchOnAway","type":"capability.switch","value":null},{"deviceList":null,"multiple":true,"name":"daysNight","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"useTimesS","type":"bool","value":""},{"deviceList":null,"multiple":true,"name":"switchOffEvening","type":"capability.switch","value":null},{"deviceList":null,"multiple":true,"name":"switchOffAway","type":"capability.switch","value":null},{"deviceList":null,"multiple":true,"name":"daysEvening","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"time11Day","type":"enum","value":"A specific time"},{"deviceList":null,"multiple":true,"name":"buttonNight","type":"capability.pushableButton","value":null},{"deviceList":null,"multiple":true,"name":"switchOnEvening","type":"capability.switch","value":null},{"deviceList":null,"multiple":true,"name":"buttonEvening","type":"capability.pushableButton","value":null},{"deviceList":null,"multiple":false,"name":"type1Evening","type":"enum","value":"Certain time"},{"deviceList":null,"multiple":true,"name":"switchOnDay","type":"capability.switch","value":null},{"deviceList":null,"multiple":false,"name":"type1Night","type":"enum","value":"Certain time"},{"deviceList":null,"multiple":false,"name":"useTimesB","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"daily","type":"bool","value":"false"},{"deviceList":{"134":"Away Mode"},"multiple":true,"name":"switchOffDay","type":"capability.switch","value":null},{"deviceList":null,"multiple":false,"name":"logging","type":"bool","value":"true"},{"deviceList":null,"multiple":false,"name":"type1Day","type":"enum","value":"Certain time"},{"deviceList":null,"multiple":true,"name":"buttonDay","type":"capability.pushableButton","value":null}],"subscriptions":[]}}}
This suggests a possibly corrupted database. You should restore to a prior one, and/or do a Backup / Soft Reset / Restore sequence. If those steps don't bring Mode Manager back, you should remove it and recreate it.
Thanks for the fast response. I tried a quick backup/restore, no go, then a backup/soft reset/restore and that didn't work either.
With that Json description I was be able to recreate my Modes without a problem, all seems fine now. Thanks for the suggestions.
