There is a bug in Mode Manager when setting modes based on presence in that the application is not restricting execution in the "Select modes NOT to change from with presence.". Screen shot attached. When can we expect this bug to be fixed?
Any updates on this? Thanks
First I've heard of it. Will investigate...
Could you please describe just what is happening?
When I choose Guest mode in the "Select modes NOT to change from presence" option, it does not honor the restriction. For example, I put my hub in Guest mode for the Nanny, then left the house, it then switched the mode to Away, when it should have remained in Guest mode. Does that help?
Yes, that's what I needed to know. I'll look into it.
Could you show me a screenshot of your App Status page for Mode Manager (gear icon left of name on Apps page, or top of page in the app itself).
Settings
Name Type Value
atTime11Day | time | 06:00 AM |
atTime11Evening | time | 6:00 PM |
atTime11Night | time | 9:00 PM |
daily | bool | false |
ignoreModes | enum | ["Away","Guest"] |
ignoreModesP | enum | ["Guest"] |
leaveArriveAway | enum | leave |
logging | bool | true |
pAnyAllAway | enum | all |
presAway | capability.presenceSensor | James, Kristin, Sherri |
presDay | capability.presenceSensor | |
presEvening | capability.presenceSensor | |
presGuest | capability.presenceSensor | |
presNight | capability.presenceSensor | |
returnAnyAll | enum | any |
returnOffSwitch | capability.switch | Guest Mode |
returnOnSwitch | capability.switch | I'm Back Routine |
returnSensors | capability.presenceSensor | James, Kristin, Sherri |
switchOffAway | capability.switch | |
switchOffDay | capability.switch | |
switchOffEvening | capability.switch | |
switchOffGuest | capability.switch | |
switchOffNight | capability.switch | |
switchOnAway | capability.switch | Goodbye Routine |
switchOnDay | capability.switch | |
switchOnEvening | capability.switch | |
switchOnGuest | capability.switch | Guest Mode |
switchOnNight | capability.switch | |
time11Day | enum | A specific time |
time11Evening | enum | A specific time |
time11Night | enum | A specific time |
timeOnlyAway | bool | |
type1Day | enum | Certain time |
type1Evening | enum | Certain time |
type1Guest | enum | Certain time |
type1Night | enum | Certain time |
useTimes | bool | true |
useTimesS | bool | true |
Event Subscriptions
Source Event Handler Filter
Goodbye Routine | switch.on | switchHandler | true |
Guest Mode | switch.on | switchHandler | true |
Guest Mode | switch.off | returnHandlerB | true |
Home (Location) | mode | modeHandler | false |
I'm Back Routine | switch.on | returnHandlerB | true |
James | presence | presenceHandler | true |
James | presence.present | returnHandler | true |
Kristin | presence | presenceHandler | true |
Kristin | presence.present | returnHandler | true |
Sherri | presence | presenceHandler | true |
Sherri | presence.present | returnHandler | true |
Application State
Name Value
earlier | {} |
shadowMode | Night |
str | Day: at 6:00 AM Evening: at 6:00 PM Night: at 9:00 PM Modes NOT to change from: Away, Guest |
strP | Use time settings for return from Away for Any of James, Kristin, Sherri arrives Away: All of James, Kristin, Sherri leave Modes NOT to change from: Guest |
strS | Use time settings for return from Away for I'm Back Routine ON Use time settings for return from Away for Guest Mode OFF Away: Goodbye Routine ON Guest: Guest Mode ON |
updated | true |
updateIgnore | true |
Scheduled Jobs
Handler Next Run Time Prev Run Time Status Schedule
timeHandlerNew | 2019-02-15 9:00:00 PM EST | 2019-02-14 9:00:00 PM EST | PENDING | 0 0 21 * * ? |
timeHandlerNew | 2019-02-15 6:00:00 PM EST | 2019-02-14 6:00:00 PM EST | PENDING | 0 0 18 * * ? |
timeHandlerNew | 2019-02-15 6:00:00 AM EST | 2019-02-14 6:00:00 AM EST | PENDING | 0 0 6 * * ? |
please hold off on this as I'm trying to reproduce the error.
I was able to reproduce using the simulated presence sensor. The app is not honoring the restriction. When I hit the arrived command on the simulated presence sensor, the app changes the mode from Guest to Home. It should keep the mode set to Guest via the bottom setting in the app. Bug fix?
OK, I have found one problem, the one you describe in this last post. If you selected a presence sensor(s) for Return from Away, it did not honor the Select Modes to NOT change from. I have fixed that problem.
But, your original post was different than this. There you described it wrongly changing mode when you left. That one I cannot reproduce.
Yes, the initial issue reported was inaccurate, but the last post is legit as you confirmed. So, you fixed it.. . Next code release? Really appreciate all the help and lighting fast TAT.
Yes, this fix will be in the next release.
Do we know when the next release will take place?
