Mode change at midnight with 2.3.1.138
Noticed my mode changed to morning at 12:00 last night, normally set to 615am. Applied the 2.3.1.138 patch late last evening. Switch to night mode went okay prior to the update.
Name Description Value Event Type Date
systemStart System startup with build: 2.3.1.138 2.3.1.138 2022-04-13 23:48:55.073 CDT
update Updated with build: 2.3.1.138 2.3.1.138
When you say
How is the mode change at 615am triggered? If you click on the "info" box in the log for the 12am mode change it should change app 261 and may tell you what made the change. Otherwise it may be a case of looking through your different rules and apps to understand where it occurred.
I'd also wonder whether there could be any relationship to this thread.... unlikely, but if @gopher.ny is looking into that part of the platform may be worth mentioning....
Off the top of my head, I don't think that's related. Please check sunrise/sunset events under Logs - Location tab to confirm.
Probably a little quick to pass it on.... So thanks for chiming in....
Mode change from Morning to Night occurs when a setting in mode manager.
@gopher.ny
Sunrise/Sunset Events. 4:09 am was me manually adjusting to night mode.
Some strange things happening here.
Was bone headed setting by this guy in mode manager!
