In ML currently one can only choose a single switch to disable turning off. Is it possible to allow more than 1 switch to disable the turning off? Thanks
Here's a simple way to get around the limitation of having a single switch:
- Create a
group with all the switches you wantvirtual switch - Create a rule such that the
groupvirtual switch is off (or on) when all the switches are off (or on). - Use the
groupvirtual switch as the switch in your Motion Lighting app.
Edit:
My initial suggestion was wrong. The corrected version works as intended.
