Mirror Switch
I need to make a new rule in rule machine I have version 2.4.4.155. I installed a switch in my garage - (Main Garage Attic Light) when I turn it on and off I want it to mirror Tammy's Attic switch. So when the Main Garage Attic Light is on Tammy's Attic is on. Same is true when Main Attic is off turn off Tammy's Attic.
![Garage Attic turns Tammys Office Attic |690x316]
(upload://uY42SlWLYS42z36f76g8lFHVuQr.jpeg)
Both Switches are Matter Switches
Why do I not not see any events in the log??
Rule 1814
Rule Machine could do this, but it’s overkill.
The mirror app can do it with less work.
Ohh - never used it. I will check it out.
In answer to the original question, in your picture you only show actions and no triggers. Your 'if light A is on turn on light B' does nothing unless something triggers the rule. I imagine you have a trigger? Always screenshot the entire rule for clarity.
Here you go. I thought I did this.
Like this?
I added 2 other lights for testing.
As you can see, there’s a lot less to configure in the mirror app than rule machine.
So does the automation work as you intended?
No, :thinking:
none of the lights trigger.
I think I might of figured it out.
No, I did not. I disabled my RM 1814 - thought that might be interfering. Still does not work.
I am missing something in the app? Looks straight forward.
Okay it is working but the wrong App is showing up in the log. Why?
Rule 1816
Your log screenshots are probably showing entries from your rule machine rule.
Apparently the mirror app doesn’t create log entries, I just checked for myself.
Ahhh - thanks
Look at the actual log entries.
They are literally the same trigger and action words from the rule machine rule you posted.
