Hey, all. I have a bunch of Inovelli switches in my house, which all work great. I recently purchased an RGBGenie remote (the one with 4 on/off/dim switches and 2 scene buttons), and am trying to get each of the first 4 switches on the remote to control a different light in my house. Simple stuff. I set up a "Mirror Me" instance with the "Mirror" map so that the 1st switch on the remote will control an Inovelli dimmer.
The first problem I'm having is that the remote doesn't seem to play nicely with other ways of operating the switch. If I turn the light on and off from the remote, it's fine. If I turn it on and off from the Hubitat interface, fine. But if I turn it on via the interface and then try to turn it off via the remote, it won't work. It's as if the remote maintains its own state of what it thinks the light should be, and if it last turned the light off, then it won't turn it off again (even if something else turned it on in the interim).
Did I set it up wrong? Is there a better way to do this than the Mirror app? Is there a way to tell the remote what the light did ("mirror back", so to speak), so it's willing to send the "off" command multiple times in a row? Is this just a failing of the RGBGenie device?
My second problem is that it's very hard to dim the lights from the remote; it can only do on and off. But I have a feeling that if I get the first problem solved and then fiddle with the device parameters, I can get this problem handled. So it's mainly just the first one.
Thanks!
