Minostan Plug in Dimmer not working since upgrading Hub to 2.3.9
Hi - C7 Hub, was on 2.3.7; skipped 2.3.8, but just updated to 2.3.9 for the new dashboard.
Now, my Minostan Zwave plug in dimmer is no longer working properly.
It will no longer respond to automations or control via the app. I can sort of get it to respond via the device page, but the response is delayed by at least 20 seconds. So the dimmer is off, I click "On" in the device page, and 20 seconds later the light associated with the dimmer goes on, and about 5 seconds after that the device page updates to show it is "on." Same delays for off.
If I power cycle the dimmer, it connects and it will receive and respond to between 1-4 commands fairly quickly, and then that is it. To get it to continue responding, I have to power cycle it again.
Per the Zwave table it is going through one other device, and it is connected at 100kbs.
Anything I can do to attempt to correct this?
I've got many Minoston devices- following along because I don't want to upgrade (I'm at 2.3.8 C7) if there are issues.
I have a Minoston plug-in dimmer and it's working perfectly fine under the latest 2.3.9.xxx release, no issues. Also have a Minoston LR plug that's working fine.
Doubtful that the platform version is the issue.
Try shutting down your hub, pulling power for 30 seconds, and then plugging it in again.
Looks like there is new firmware this month for this device.
Now I have to figure out how to update device firmware with Hubitat. Always something...
THANK YOU!! That seems to have resolved it!! I also killed power to the outlet for about 10 seconds for good measure..
Per the Zwave details, it went from over 26,000 ms response, down to 9 ms response.
Oddly, it rerouted, and now goes through 2 other devices, and went from 100 kbs to 40 kbs, but it responding consistently.
THANK YOU!
I never did update the driver because I can't really figure out how to do that, but thanks to you it's working so I don't need to figure it out.
THANK YOU!
