I used ChatGPT and Claude to fix this base driver for the MP21ZD/MP31ZD. Seems to work well and exposes parameters for easy changes. Feel free to copy/use/modify. (updated to add ability to easily set any configuration parameter and also list parameter names versus just numbers) - just updated from 1.5.3 to 1.5.6 removing 'sensor' capability that was confusing alexa and implementing a 'on/off/ status check each hour (default) to assure no missed on/off status get out of synch with Hubitat.
* Minoston Smart Plug Dimmer v1.5.6 (Hubitat, MP21ZD/MP31ZD firmware 8.0)
* Models: MP21ZD/MP31ZD
* Author:
* winnie (sky-nie)
* Documentation:
* Original driver: winnie (sky-nie), 2022.
* Hubitat compatibility revisions: OpenAI ChatGPT, October 2026; Claude (Anthropic), October 2026.
* These are independent modifications, not an official Minoston release.
* Changelog:
* 1.5.6-test (10/20/2026) - Claude (Anthropic)
* - On/off state check is on by default: a blank interval now means 60 minutes (only an
* explicit 0 disables it), and it is scheduled when the device is first installed.
* - Removed the Health Check capability and ping(); nothing scheduled ping(), and the
* periodic on/off check now does that job.
* 1.5.5-test (10/20/2026) - Claude (Anthropic)
* - Removed the generic "Sensor" capability. It has no attributes for this plug-in dimmer, and
* the Amazon Alexa skill was treating the device as a temperature sensor and logging
* "Alexa.TemperatureSensor.temperature ... attribute is uninitialized" warnings.
* 1.5.4-test (10/19/2026) - Claude (Anthropic)
* - New preference "On/Off State Check Interval" (0 disables; 1-1440 minutes). Periodically
* asks for the current level/on-off state to correct a missed report.
* - First check after hub startup or Save Preferences runs at a random 1-10 minutes, so
* devices do not all query at once; later checks follow the interval.
* - Added the Initialize capability so the check restarts after a hub reboot.
* - A change found by the check is logged and sent as [status check] / type digital,
* not [physical], so rules that react to physical presses are not triggered.
* 1.5.3-test (10/12/2026) - Claude (Anthropic)
* - Old "configParamN" state entries are renamed as soon as the driver runs anything
* (Save, Configure, Refresh, Read Configuration or any device message), with a log line.
* 1.5.2-test (10/12/2026) - Claude (Anthropic)
* - State variables now show parameter names, e.g. "param02 LED Indicator Mode",
* zero-padded so they sort in order. Old "configParamN" entries are converted automatically.
* - Values read back for unlisted parameters (via Set Configuration Parameter) are kept in state too.
* 1.5.1-test (10/12/2026) - Claude (Anthropic)
* - Added Set Configuration Parameter command (parameter number, length, value).
* Writes the value, reads it back, and logs the result. Parameters 0 and 255 are refused.
* 1.5.0-test (10/12/2026) - Claude (Anthropic)
* - Blank preferences are unmanaged: Configure/Save write only parameters you have set,
* never driver defaults. Configure no longer rewrites every parameter on first run.
* - Reported parameter values are copied into Preferences, so the page shows the device's
* actual settings after Read Configuration (or Configure).
* - New "Apply changed settings when saving preferences" option (default on); Configure
* still applies pending changes manually and then reads all parameters back.
* - Follow-up status queries after on/off/setLevel are now actually sent (sendHubCommand);
* commands returned from scheduled methods were previously discarded.
* - A Basic Report of 0xFF no longer sets level to 255; device level 99 is shown as 100%.
* - setLevel tolerates missing or text durations; duration limited to 0-30 seconds.
* - lastCheckIn is updated at most once per hour instead of on every message.
* - Added description logging and physical/digital event types.
* - Debug/trace logging turns off automatically after 30 minutes.
* - One-time upgrade step: preferences saved by v1.4 (which held driver defaults) are
* cleared and reloaded from the device; nothing is written during the upgrade.
* - Removed SmartThings-only metadata, checkInterval events and the unused multi-channel handler.
* 1.4.0-test (10/07/2026) - OpenAI ChatGPT
* - Added parameter 12 (maximum brightness) to editable preferences.
* - Verified 800-series manual: 1 byte, 0 disables limit, 1-99 sets limit.
* - Set parameter 12 initial preference to 0 to match tested device.
* - Kept manual-only Configure and read-only Read Configuration.
* - Preserved original author credit and earlier revisions.
* 1.3.0-test (10/07/2026) - OpenAI ChatGPT
* - Documented successful user testing on MP21ZD firmware 8.0, S2.
* - Added read-only query of parameter 12 (maximum brightness),
* without assuming its size/range or exposing a write control.
* - Retained separate optional debug/trace logging controls.
* - Retained read-only configuration inspection and manual-only writes.
* 1.2.0-test (10/07/2026) - OpenAI ChatGPT
* - Added configurable debug/trace logging, default off.
* - Added Read Configuration without writing device parameters.
* - Stopped automatic configuration writes on preference save.
* 1.1.0-test (10/07/2026) - OpenAI ChatGPT
* - Revised S0/S2 command encapsulation and Supervision handling.
* - Added multichannel parsing, refreshed state reporting and version query.
* - Corrected undefined supervision parsing reference.
* 1.0.1 (06/18/2022)
* - fix a bug: the switch status is not fresh when it is controlled on the device
* 1.0.0 (03/19/2022)
* - Initial Release
* Referenceļ¼
* https://github.com/krlaframboise/SmartThings/blob/master/devicetypes/krlaframboise/eva-logik-in-wall-smart-dimmer.src/eva-logik-in-wall-smart-dimmer.groovy
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
import groovy.transform.Field
@Field static final String DRIVER_VERSION = "1.5.6"
// A state change reported within this window after a periodic check is attributed to the check.
@Field static final long SWITCH_CHECK_WINDOW_MS = 15000L
@Field static final int DEFAULT_SWITCH_CHECK_MINUTES = 60
// Names shown in State Variables. Parameters not listed here appear as "(unknown)".
@Field static final Map PARAM_STATE_NAMES = [
2: "LED Indicator Mode",
4: "Auto Turn-Off Timer",
6: "Auto Turn-On Timer",
7: "Night Light",
8: "Power Failure Recovery",
9: "Push Dimming Duration",
10: "Hold Dimming Duration",
11: "Minimum Brightness",
12: "Maximum Brightness"
// Bump only if preferences ever need clearing again; a normal version bump must not clear them.
@Field static final int PREF_SCHEMA = 2
metadata {
definition (
name: "Minoston Smart Plug Dimmer(MP21ZD)",
namespace: "sky-nie",
author: "winnie",
importUrl: "https://raw.githubusercontent.com/sky-nie/hubitat/main/minoston/minoston-smart-plug-dimmer.groovy"
capability "Actuator"
capability "Switch"
capability "Switch Level"
capability "Configuration"
capability "Refresh"
capability "Initialize"
attribute "firmwareVersion", "string"
attribute "lastCheckIn", "string"
attribute "syncStatus", "string"
command "readConfiguration"
command "setConfigurationParameter", [
[name: "Parameter number*", type: "NUMBER", description: "1-254"],
[name: "Parameter length*", type: "ENUM", constraints: ["1", "2", "4"], description: "Size in bytes"],
[name: "Value*", type: "NUMBER", description: "Value to write"]
fingerprint mfr: "0312", prod: "FF00", deviceId: "FF0D", deviceJoinName: "Minoston Smart Plug Dimmer", inClusters:"0x5E,0x55,0x9F,0x6C" //MP21ZD
fingerprint mfr: "0312", prod: "FF00", deviceId: "FF0D", deviceJoinName: "Minoston Smart Plug Dimmer", inClusters:"0x86,0x26,0x70,0x85,0x8E,0x71,0x31,0x59,0x72,0x5A,0x73,0x7A"
preferences {
input "txtEnable", "bool", title: "Enable description logging", defaultValue: true
input "enableDebugLogging", "bool", title: "Enable debug logging (turns off after 30 minutes)", defaultValue: false
input "enableTraceLogging", "bool", title: "Enable trace logging (turns off after 30 minutes)", defaultValue: false
input "applyOnSave", "bool", title: "Apply changed settings when saving preferences (otherwise use Configure)", defaultValue: true
input "switchCheckInterval", "number", title: "On/Off State Check Interval (0 disables; 1-1440 minutes; blank = 60)",
description: "Re-reads on/off and level to correct a missed report. First check runs 1-10 minutes after startup or save.",
required: false, range: "0..1440", defaultValue: 60
configParams.each {
// No defaultValue: a blank preference means "leave the device's value alone".
if (it.range) {
input "configParam${it.num}", "number", title: "${it.name}:", required: false, range: it.range,
description: "Blank = unchanged. Factory default ${it.factoryDefault}"
} else {
input "configParam${it.num}", "enum", title: "${it.name}:", required: false, options: it.options,
description: "Blank = unchanged"
// Lifecycle
def installed() {
logDebug "installed()..."
state.prefSchema = PREF_SCHEMA
runIn(5, "readConfiguration")
scheduleSwitchCheck()
def updated() {
if (isDuplicateCommand(state.lastUpdated, 5000)) return []
state.lastUpdated = new Date().time
logDebug "updated()..."
unschedule("logsOff")
if (enableDebugLogging || enableTraceLogging) runIn(1800, "logsOff")
migrateParamStateKeys()
if (migrateIfNeeded()) return []
if (applyOnSave != false) {
sendConfigChanges()
} else {
refreshSyncStatus()
return []
// Runs at hub startup (Initialize capability), so the periodic check survives reboots.
def initialize() {
logDebug "initialize()..."
// Periodic on/off state check (preference "switchCheckInterval", minutes; 0 = disabled).
// One Switch Multilevel Get per check; the report updates both switch and level.
private int switchCheckMinutes() {
def raw = settings?.switchCheckInterval
// Hubitat applies a preference's defaultValue only when Preferences are saved, so a blank
// (never-saved) setting means the default here. Only an explicit 0 disables the check.
if (raw == null || "${raw}".trim() == "") return DEFAULT_SWITCH_CHECK_MINUTES
int m = safeToInt(raw, -1)
if (m < 0 || m > 1440) {
log.warn "${device.displayName}: On/off check interval must be 0-1440 minutes; received ${raw}. Check disabled."
return 0
return m
// First run lands at a random 1-10 minutes so devices started together do not all query at once.
private void scheduleSwitchCheck() {
unschedule("switchStateCheck")
int m = switchCheckMinutes()
if (m > 0) {
int first = 60 + new Random().nextInt(541) // 60-600 seconds
runIn(first, "switchStateCheck")
logDebug "On/off check every ${m} min; first check in ${first} s"
} else {
logDebug "On/off check disabled"
def switchStateCheck() {
if (m <= 0) return
try {
state.switchCheckAt = new Date().time
logDebug "Periodic on/off check (switch is ${device.currentValue('switch')}, level ${device.currentValue('level')})"
sendCommands([switchMultilevelGetCmd()])
} catch (e) {
log.warn "${device.displayName}: periodic on/off check failed: ${e.message}"
} finally {
runIn(m * 60, "switchStateCheck")
def logsOff() {
device.updateSetting("enableDebugLogging", [value: "false", type: "bool"])
device.updateSetting("enableTraceLogging", [value: "false", type: "bool"])
log.info "${device.displayName}: debug and trace logging disabled"
// Applies pending changes (only preferences you have set), then reads every parameter back.
def configure() {
logDebug "configure()..."
List cmds = configChangeCommands()
cmds.addAll(configReadCommands())
sendCommands(cmds, 300)
runIn(Math.max(8, (int)(cmds.size() * 0.3) + 4), "refreshSyncStatus", [overwrite: true])
return []
// Read only: requests the current values without modifying the device.
def readConfiguration() {
logDebug "Reading configuration parameters (no writes)"
sendCommands(configReadCommands(), 300)
runIn(8, "refreshSyncStatus", [overwrite: true])
return []
private void sendConfigChanges() {
if (cmds) {
logDebug "Writing ${cmds.size() / 2} changed parameter(s)"
runIn(Math.max(6, (int)(cmds.size() * 0.3) + 4), "refreshSyncStatus", [overwrite: true])
} else {
refreshSyncStatus()
private List configChangeCommands() {
List cmds = []
configParams.each { param ->
if (param.value == null) return // blank preference: unmanaged
def storedVal = getParamStoredValue(param.num)
if (storedVal != null && storedVal == param.value) return
if (txtEnable) log.info "${device.displayName}: setting ${param.name} (#${param.num}) to ${param.value}"
cmds << secureCmd(zwave.configurationV1.configurationSet(parameterNumber: param.num, size: param.size, scaledConfigurationValue: param.value))
cmds << secureCmd(zwave.configurationV1.configurationGet(parameterNumber: param.num))
return cmds
private List configReadCommands() {
return configParams.collect { secureCmd(zwave.configurationV1.configurationGet(parameterNumber: it.num)) }
// One-time upgrade from v1.4 and earlier. Those versions saved every preference with a
// driver default, so the stored preferences may not reflect anything you chose. Clear them
// and read the real values from the device, which then fill Preferences.
// Returns true when the migration ran (callers should not write configuration this time).
private boolean migrateIfNeeded() {
if (state.prefSchema == PREF_SCHEMA) return false
state.remove("resyncAll")
configParams.each { device.removeSetting("configParam${it.num}") }
log.warn "${device.displayName}: upgraded to v${DRIVER_VERSION}; parameter preferences cleared and are being " +
"reloaded from the device. Nothing was written. Review Preferences, then change and save as needed."
runIn(2, "readConfiguration", [overwrite: true])
return true
// Commands
// Writes any configuration parameter, then reads it back. The readback is logged and,
// for parameters listed in Preferences, copied into the matching preference.
def setConfigurationParameter(parameterNumber, parameterLength, value) {
try {
int p = safeToInt(parameterNumber, -1)
int n = safeToInt(parameterLength, -1)
if (value == null || !"${value}".trim().matches(/-?\d+(\.0+)?/)) throw new IllegalArgumentException("value must be a whole number")
long v = new BigDecimal("${value}".trim()).longValue()
if (p == 255) throw new IllegalArgumentException("parameter 255 is commonly a reset parameter and is blocked by this driver")
if (p < 1 || p > 254) throw new IllegalArgumentException("parameter number must be 1-254")
if (!(n in [1, 2, 4])) throw new IllegalArgumentException("length must be 1, 2 or 4 bytes")
long min = -(1L << (8 * n - 1))
long max = (1L << (8 * n)) - 1
if (v < min || v > max) throw new IllegalArgumentException("value must be ${min} to ${max} for ${n} byte(s)")
// Unsigned values above the signed range are sent as their two's-complement equivalent (same bytes).
long signedMax = (1L << (8 * n - 1)) - 1
int wire = (int) (v > signedMax ? v - (1L << (8 * n)) : v)
log.info "${device.displayName}: writing parameter #${p}, length ${n}, value ${v}"
sendCommands([
secureCmd(zwave.configurationV1.configurationSet(parameterNumber: p, size: n, scaledConfigurationValue: wire)),
secureCmd(zwave.configurationV1.configurationGet(parameterNumber: p))
], 500)
} catch (e) {
log.error "${device.displayName}: parameter write rejected: ${e.message}"
def refresh() {
logDebug "refresh()..."
refreshSyncStatus()
sendCommands([switchMultilevelGetCmd(), secureCmd(zwave.versionV1.versionGet())], 300)
// Scheduled follow-up after a digital command; must send its own commands because
// values returned from scheduled methods are not transmitted.
def refreshSwitch() {
def on() {
logDebug "on()..."
markDigital()
runIn(2, "refreshSwitch", [overwrite: true])
return [ basicSetCmd(0xFF) ]
def off() {
logDebug "off()..."
markDigital()
return [ basicSetCmd(0x00) ]
def setLevel(level) {
logDebug "setLevel($level)..."
return setLevel(level, 1)
def setLevel(level, duration) {
logDebug "setLevel($level, $duration)..."
int durationVal = validateRange(duration, 1, 0, 30)
markDigital()
runIn(Math.max(2, durationVal + 1), "refreshSwitch", [overwrite: true])
return [ switchMultilevelSetCmd(level, durationVal) ]
private switchMultilevelGetCmd() {
return secureCmd(zwave.switchMultilevelV3.switchMultilevelGet())
private basicSetCmd(val) {
return secureCmd(zwave.basicV1.basicSet(value: val))
private switchMultilevelSetCmd(level, int durationVal) {
// Z-Wave levels are 0-99; 100% is sent as 99.
int levelVal = validateRange(level, 99, 0, 99)
return secureCmd(zwave.switchMultilevelV3.switchMultilevelSet(dimmingDuration: durationVal, value: levelVal))
private void markDigital() {
state.lastDigitalCmd = new Date().time
// Parsing
def result = []
try {
migrateIfNeeded()
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result.addAll(zwaveEvent(cmd) ?: [])
} else {
logDebug "Unable to parse description: $description"
updateLastCheckIn()
} catch (e) {
log.error "${device.displayName}: parse error: $e"
return result
private void updateLastCheckIn() {
long nowMs = new Date().time
Long last = state.lastCheckInMs as Long
if (last == null || nowMs - last >= 60 * 60 * 1000L) {
state.lastCheckInMs = nowMs
sendEvent(name: "lastCheckIn", value: convertToLocalTimeString(new Date()))
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
logTrace "SecurityMessageEncapsulation: ${cmd}"
def encapCmd = cmd.encapsulatedCommand(commandClassVersions)
def result = []
if (encapCmd) {
result.addAll(zwaveEvent(encapCmd) ?: [])
} else {
log.warn "${device.displayName}: unable to extract encapsulated cmd from $cmd"
return result
def zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd) {
logTrace "SupervisionGet: ${cmd}"
def inner = cmd.encapsulatedCommand(commandClassVersions)
if (inner) {
zwaveEvent(inner)
} else {
log.warn "${device.displayName}: unable to extract supervised command: ${cmd}"
def report = zwave.supervisionV1.supervisionReport(
sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false,
status: inner ? 0xFF : 0x00, duration: 0
sendHubCommand(new hubitat.device.HubAction(secureCmd(report), hubitat.device.Protocol.ZWAVE))
return []
def zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionReport cmd) {
logTrace "SupervisionReport: ${cmd}"
return []
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
logTrace "ConfigurationReport: ${cmd}"
sendEvent(name: "syncStatus", value: "Syncing...")
runIn(4, "refreshSyncStatus", [overwrite: true])
def param = configParams.find { it.num == cmd.parameterNumber }
def val = cmd.scaledConfigurationValue
if (param) {
if (txtEnable) log.info "${device.displayName}: ${param.name} (#${param.num}) = ${val}"
setParamStoredValue(param.num, val)
syncPreference(param, val)
} else {
// Unlisted parameter (e.g. from Set Configuration Parameter): keep and always log the readback.
setParamStoredValue(cmd.parameterNumber, val)
log.info "${device.displayName}: parameter #${cmd.parameterNumber} (size ${cmd.size}) = ${val}"
return []
// Copy the device's reported value into Preferences so the page reflects the device.
private void syncPreference(Map param, val) {
try {
String name = "configParam${param.num}"
if ("${settings[name]}" == "${val}") return
if (param.options) {
if (!param.optionKeys.contains("${val}")) {
log.warn "${device.displayName}: ${param.name} reported unlisted value ${val}; preference left unchanged"
return
device.updateSetting(name, [value: "${val}", type: "enum"])
} else {
device.updateSetting(name, [value: val, type: "number"])
logDebug "Preference ${name} synchronized to ${val}"
} catch (e) {
log.warn "${device.displayName}: could not synchronize preference for #${param.num}: ${e.message}"
def refreshSyncStatus() {
def changes = pendingChanges
sendEvent(name: "syncStatus", value: (changes ? "${changes} Pending Changes" : "Synced"))
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
logTrace "VersionReport: ${cmd}"
def subVersion = String.format("%02d", cmd.applicationSubVersion)
def fullVersion = "${cmd.applicationVersion}.${subVersion}"
sendEvent(name: "firmwareVersion", value: fullVersion)
return []
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
logTrace "BasicReport: ${cmd}"
sendSwitchEvents(cmd.value)
return []
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
logTrace "SwitchMultilevelReport: ${cmd}"
return []
def zwaveEvent(hubitat.zwave.Command cmd) {
logDebug "Unhandled zwaveEvent: $cmd"
return []
private void sendSwitchEvents(rawVal) {
int raw = safeToInt(rawVal, 0)
if (raw == 0xFE) { // "unknown" per Z-Wave spec
logDebug "Device reported unknown level"
return
Long lastDigital = state.lastDigitalCmd as Long
Long lastCheck = state.switchCheckAt as Long
boolean fromCommand = lastDigital != null && nowMs - lastDigital < 5000
boolean fromCheck = lastCheck != null && nowMs - lastCheck < SWITCH_CHECK_WINDOW_MS
// A correction found by the periodic check is not a button press: send it as digital.
String type = (fromCommand || fromCheck) ? "digital" : "physical"
String source = fromCommand ? "digital" : (fromCheck ? "status check" : "physical")
// One report answers one check; clear the marker so a later button press is still "physical".
if (fromCheck) state.remove("switchCheckAt")
String switchVal = raw ? "on" : "off"
if (device.currentValue("switch") != switchVal) {
String desc = "${device.displayName} was turned ${switchVal} [${source}]"
if (txtEnable) log.info desc
sendEvent(name: "switch", value: switchVal, type: type, descriptionText: desc)
// Only real levels (1-99) update level; 0xFF means "on" without a level.
if (raw >= 1 && raw <= 99) {
int levelPct = (raw == 99) ? 100 : raw
if (safeToInt(device.currentValue("level"), -1) != levelPct) {
String desc = "${device.displayName} level is ${levelPct}% [${source}]"
sendEvent(name: "level", value: levelPct, unit: "%", type: type, descriptionText: desc)
// Helpers
private String secureCmd(hubitat.zwave.Command cmd) {
return zwaveSecureEncap(cmd.format())
private void sendCommands(List cmds, Integer delay = 300) {
def valid = cmds?.findAll { it }
if (valid) sendHubCommand(new hubitat.device.HubMultiAction(delayBetween(valid, delay), hubitat.device.Protocol.ZWAVE))
private static getCommandClassVersions() {
0x20: 1, // Basic
0x26: 3, // Switch Multilevel
0x55: 1, // Transport Service
0x59: 1, // AssociationGrpInfo
0x5A: 1, // DeviceResetLocally
0x5E: 2, // ZwaveplusInfo
0x71: 3, // Notification
0x6C: 1, // Supervision
0x70: 1, // Configuration
0x7A: 2, // FirmwareUpdateMd
0x72: 2, // ManufacturerSpecific
0x73: 1, // Powerlevel
0x85: 2, // Association
0x86: 1, // Version (2)
0x8E: 2, // Multi Channel Association
0x98: 1, // Security S0
0x9F: 1 // Security S2
// Counts only preferences you have set that differ from (or have not yet been confirmed by) the device.
private getPendingChanges() {
return configParams.count { it.value != null && it.value != getParamStoredValue(it.num) }
private getParamStoredValue(paramNum) {
return safeToInt(state[paramStateKey(paramNum)], null)
private void setParamStoredValue(paramNum, val) {
state[paramStateKey(paramNum)] = val
// e.g. "param02 LED Indicator Mode"; zero-padded so State Variables sort numerically.
private static String paramStateKey(paramNum) {
int n = safeToInt(paramNum, 0)
String name = PARAM_STATE_NAMES[n] ?: "(unknown)"
return String.format("param%02d %s", n, name)
// Converts entries from v1.5.1 and earlier ("configParam2") to the named form.
private void migrateParamStateKeys() {
def oldKeys = state.keySet().findAll { "${it}" ==~ /configParam\d+/ }
if (!oldKeys) return
log.info "${device.displayName}: renaming ${oldKeys.size()} parameter state entries to named form"
oldKeys.each { key ->
int n = "${key}".substring("configParam".length()).toInteger()
def val = state[key]
String newKey = paramStateKey(n)
if (state[newKey] == null) state[newKey] = val
state.remove(key)
// Configuration Parameters
private getConfigParams() {
ledModeParam,
autoOffIntervalParam,
autoOnIntervalParam,
nightLightParam,
powerFailureRecoveryParam,
pushDimmingDurationParam,
holdDimmingDurationParam,
minimumBrightnessParam,
maximumBrightnessParam
private getLedModeParam() {
return getParam(2, "LED Indicator Mode", 1, 0, ledModeOptions)
private getAutoOffIntervalParam() {
return getParam(4, "Auto Turn-Off Timer(0, Disabled; 1 - 65535 minutes)", 4, 0, null, "0..65535")
private getAutoOnIntervalParam() {
return getParam(6, "Auto Turn-On Timer(0, Disabled; 1 - 65535 minutes)", 4, 0, null, "0..65535")
private getNightLightParam() {
return getParam(7, "Night Light Settings(1 - 10:10% - 100%)", 1, 2, null, "1..10")
private getPowerFailureRecoveryParam() {
return getParam(8, "Power Failure Recovery", 1, 2, powerFailureRecoveryOptions)
private getPushDimmingDurationParam() {
return getParam(9, "Push Dimming Duration(0, Disabled; 1 - 10 Seconds)", 1, 2, null, "0..10")
private getHoldDimmingDurationParam() {
return getParam(10, "Hold Dimming Duration(1 - 10 Seconds)", 1, 4, null, "1..10")
private getMinimumBrightnessParam() {
return getParam(11, "Minimum Brightness(0, Disabled; 1 - 99:1% - 99%)", 1, 10, null,"0..99")
private getMaximumBrightnessParam() {
// 800-series manual: size=1, 0 disables maximum limit, 1..99 limits maximum brightness.
// Manufacturer factory default is 99; a tested MP21ZD (firmware 8.0) reported 0.
return getParam(12, "Maximum Brightness (0 = Disabled; 1-99 = Limit)", 1, 99, null, "0..99")
// value is null when the preference is blank (unmanaged).
private getParam(num, name, size, factoryDefault, options = null, range = null) {
def val = safeToInt((settings ? settings["configParam${num}"] : null), null)
def map = [num: num, name: name, size: size, value: val, factoryDefault: factoryDefault]
if (options) {
map.valueName = options?.find { k, v -> "${k}" == "${val}" }?.value
map.options = setDefaultOption(options, factoryDefault)
map.optionKeys = options.keySet().collect { "${it}" }
if (range) {
map.range = range
return map
private static setDefaultOption(options, defaultVal) {
return options?.collect{ k, v ->
if ("${k}" == "${defaultVal}") {
v = "${v} [FACTORY DEFAULT]"
["$k": "$v"]
private static getLedModeOptions() {
return [
"0":"Off When On",
"1":"On When On",
"2":"Always Off",
"3":"Always On"
private static getPowerFailureRecoveryOptions() {
return [
"0":"Turn Off",
"1":"Turn On",
"2":"Restore Last State"
private static int validateRange(val, int defaultVal, int lowVal, int highVal) {
int v = safeToInt(val, defaultVal)
return Math.max(lowVal, Math.min(highVal, v))
// Accepts integers, decimals ("5.0", 5.0) and numeric strings; anything else returns defaultVal.
private static safeToInt(val, defaultVal = 0) {
if (val == null) return defaultVal
if (val instanceof Number) return ((Number) val).intValue()
String s = "${val}".trim()
if (s.isInteger()) return s.toInteger()
if (s.isBigDecimal()) return new BigDecimal(s).intValue()
return defaultVal
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
} else {
return "$dt"
private static isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
if (settings?.enableDebugLogging == true) log.debug "${device.displayName}: $msg"
private logTrace(msg) {
if (settings?.enableTraceLogging == true) log.trace "${device.displayName}: $msg"
