Hi!
My hub arrived today (UK) and I'll be starting to move things over to Hubitat over the never few days.
I use actiontiles extensively, so I think this will be something I'll need to retain SmartThings for.
Is there a recommended approach or best practice for migrating from smartthings?
I have some announcements that play on various sonos speakers via bigtalker is there anything similar similar in hubitat?
Cheers,
D
Cobra
May 5, 2018, 1:31pm
2
SmartTiles is compatible but I don’t know that ActionTiles is yet.. you need to ask the author
BT has not been ported yet as we don’t have TTS (think it’s coming in the next release)
You could use mp3 event player while you are waiting for TTS
OK.. as the Sonos integration has been released it's time for an app
As I've only had a short time to test this since the integration was released, I'm calling this a BETA
Hopefully, when a few more people test it, if everything is ok then I'll mark it as a release.
PLEASE if you find any bugs or find it doesn't work for you let me know.. I can't fix what I don't know about
This will allow you to play any mp3 hosted on a website, either locally or on the interne…
Andy
You can use our built-in Hubitat Dashboard to replace ActionTiles. It covers virtually all of the functionality.
TTS is released. See Hub Update 1.0.8
Thanks so much for the quick replies!
I've moved successfully my first motion sensor and set up a basic lighting rule!
I have a number of single fibaro switches. I see a device handler for the dual but not for the single though unfortunately.. any ideas how I could get these working?
This will probably work with one of the generic zwave switch drivers.
